In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Garage siding- need sheathing?
| Posted in Construction Techniques on December 24, 2002 06:08am
I am building a garage extension, 10′ x 14′.  The original is sheathed with 3/4″ cedar (I think) shiplap siding and nothing else (no ply, etc.).  It is probably 60-70 years old.
I am putting on pine 3/4″ shiplap siding, because it was the only thing I could find that matches the existing profile (#106 or 107, coved at the top, sometimes called “specialty”).  But the pine seems pretty floppy.
I wasn’t planning on sheathing with ply or OSB, but now I am wondering if that is a bad choice.  The pine probably has enough tensile strength, but its lack of stiffness worries me.
Should I sheath first even though the original is just sided?
One other question: I am planning on using 8 penny galvanized box nails to hold the siding (instead of finish nails that were used on the original).  Any thoughts on that?
 Thanks, and happy holidays to all.
  1. FrankB89 | Dec 24, 2002 07:05pm | #1
    I personally prefer double wall construction, especially if you're going to insulate.  The only time I see siding put right to the studs (over a vapor barrier) is on economical tract-type construction.  But then, I tend to overbuild a little in other areas too.
    I'd probably use galvanized 8d casing nails myself, but then, I live in a sometimes damp climate.
    Jules Quaver for President   2004
  2. patren61270 | Dec 24, 2002 07:09pm | #2
          In answer to your question, i believe that siding over studs was an inexpensive alternative to the old dilema of whether or not sheathing and wood siding should go against each other. The thought was that the two back to back would cause moisture buildup and premature aging of the exterior siding and rot from the inside out. It was thought better to have the siding simply as an outside protection on the outside of the studding. The existing garage should have let in bracing at all four corners for stability against wind and the loads of the structure itself. As far as nails are concerned, I would use a galvanized splitless siding nail. They are a little more costly but have less chance of splitting the board when nailed close to corners or an end of a board where a butt joint would meet on a stud. I guess then... that whether you need sheathing is a matter of matching the new siding with the old and if you have let in bracing in the new structure.
    MERRY CHRISTMAS AND GOOD LUCK!
    JACK OF ALL TRADES      (AKA) PATTERSON RENOVATION
Considerations for Building a Successful Staircase
Join award-winning architect Duo Dickinson as he takes an in-depth look at designing and building a beautiful, successful staircase on Wednesday, May 18, at 6pm ET.
  • Decompartmentalizing a 1940s San Francisco Home
  • Podcast 460: PRO TALK With Builder Keith Bohling
  • How to Frame an I-Joist Roof
  • Designer Kitchen Cabinets on a Budget
Justin Fink Deck Building Course announcement
Sign Up See all newsletters
BOOKS, DVDs, & MERCH
Shop the Store
  • Outdoor Projects
    Buy Now
    Buy Now
  • Tool Guide 2022
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Shop the Store
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • Issue 304 - Dec 2021/Jan 2022
    • Why You Need Blower-Door Testing
    • Passive-House Standards for Everyone
    • Window Replacement With a Side of Rot Repair
  • Issue 303 - November 2021
    • Compact Cordless Miter Saws
    • Maximize Space with Thoughtful Built-Ins
    • 10 Essentials for Quality Trim Carpentry
  • twitter
Sign Up
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
