GFCI duplex outlet on dimmer circut ?
I want to add a duplex outlet for under cabinet incandecent lighting with dimmer, however outlet would be near enough to sink to normally require GFCI protection. If I use a GFCI outlet will it be compatable with a dimmer ?
Put the GFCI outlet somewhere else and draw power for your dimmer from the load terminals.
My thanks to you and Benjamin for your quick reply, I knew that someone would have the "key" to my situation.
