BobChapman
| Posted in General Discussion on
I have just bought a new manlift that has 110VAC power delivered to the working cage at the top of the lift, with a GFCI-protected outlet. Today I was using it to trim some trees. After a few cuts with my electric chainsaw, the GFCI quit. I went off to my electrical supplier and got a replacement, which also quit after ten minutes of use.
I know that I’m not drawing more than the 15 amps that it’s supposed to be good for.
Is it the saw motor that is somehow fouling up the GFCI? anyone know?
Bob Chapman
I have read that some motors trip GFCIs for no reason.
I run my chop saw and table saw off an outside GFI outlet with no problems other than the occasional trip at plug in. I have never had it trip while I was running the saws.
"Though I don't think" added Deep Thought "that you're going to like it."
Thanks for your thoughts
Bob
Some electric motors tend to trip GFCIs. Most likely with brush-type motors.
Bob,
I rented a manlift on Memorial day weekend to finish my facia / soffit replacement project. I had to do a lot of sheathing trimming with my circular saw and had no problems with it tripping the GFI. My detached garage has GFI breakers on everything and I dont have any problems using power tools.
Hope this helps,
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
I wonder if the chainsaw has a short, or soemthing like that. When it touches the tree it would definitely be grounded, so that would trip a GFCI.
When you say the "GFCI quit", do you mean it tripped? Or did it burn out completely?
When was the last time you checked the brushes. GFCIs function by sensing current imbalance between the legs on the circuit. It the if the brushes are bad there may be enough arcing to trip it.
