I had granite counters fabricated for a spec. remodel I am doing. I have to seam it at the sink. Just recently I was doing a kitchen, and the cabinet co. had a granite fabricator do the counter tops. When they did the seam, they used a PSA sanding disc, at about 1000 grit, to buff the seam and smooth the epoxy-seam fill. They spoke very little English so I couldn’t get a clear answer if the sanding disc was a special material, or just a generic type of sanding disc. Would anyone know what kind of sanding disc you would use to buff the granite?
By considering things like energy-efficient mechanicals, window orientation, and renewable energy sources, homes can be evaluated to meet the energy codes. Here's what the IRC has to say.
El carburo del silicio abre el abrigo.
http://www.imiweb.org/stonemagazine/dimston1.htm
This mag has lots of ads for those tools. Joe H
We install quite a few granite counter tops and never do any sanding when installing. Instead we apply tape to mask each exposed face of granite to be joined, place the stone properly , fill the seam with filler, and then use a single edged razor as a putty knife. We then peel off the tape and clean up with another fresh razor. Works every time.
Good luck.
the type of sandpaper grit after a certain point is registered as microns 60,70,80,-etc. there very fine and stand up to the slurry thats created regular sandpaper will stand up but the "special " microns enhances that medium your using. porter cable makes this paper i could only find 6" in my neck of the woods. and it's not cheap. i do a final with ash( volcanic), than talcum powder with surprising good results. than a sealer, let me say though i'm a carpenter that worked with a stone guy for 6 months back in the early nineties. but i get pretty good results but nothing replaces a professionals advice......... when all else fails ......the internet is my pal....cheers bear
