OK, I took your advice and am installing 5/8 inch drywall on the ceiling of my basement that has truss joists which are 24 inches on center. It’s working well so far. But what about the bathroom? The shower won’t be used on a daily basis, there’s an exhaust fan and I have a heat pump dedicated to the basement. Since I’m still contending with those joists 24 inches on center and I can’t find 5/8 inch green board here; only the 1/2 inch board, I thought of just installing the regular 5/8 drywall since I will likely paint the bathroom with enamel anyway. Am I asking for trouble?
My sheetrockers told me that green board cannot be used on ceilings, even with rafters !6"oc. "It will fall apart", they said.
*That's the same thing I've been told - greenboard is for walls only. I don't think it has the fibers running through it, or some such. - jb
*You mean the grain is wrong.
*Don't think it's a grain thing -- the mfr just says don't do it. The core must be different. reg. d'wall ceiling should be OK unless you let the bath get too damp -- condensation and such -- and if you do you'll have other problems anyway. Use the fan!Our county now says that if greenboard is used in bath, vapor barrier must go OVER it (inside). I'm not sure how that works... I'm just not going to use the stuff period.
* James,
*Thank You, I've been blocking in 24oc trusses to 12oc for years to put up green board in bathrooms.
