Any one use these? Comments?
If so is there a maximum size window you would install WITHOUT frame srews (relying on just the fin nails/screws)?
John
John
Framing the floor inside a crawlspace foundation keeps a gable-end addition close to grade.
John
Properly shimmed, the weight of a window should be carried by the bottom corners of the window which sit on the frame of the opening (on the shims).
Never have used the screws you mention.
