gypsum sheathing and aluminum faced ply
moltenmetal | Posted in General Discussion on October 13, 2005 10:42am
Everywhere I look these days, I’m seeing that yellow or silver-coloured Georgia Pacific fibreglass-faced gypsum board used as sheathing.  So I cruised over to the Georgia Pacific website and apparently, this stuff meets code requirements as a structural sheathing.  It even comes with a 90 day weather-resistance guarantee! (I’ve seen a lot of it up for more than 90 days before it’s covered- wonder what you’re supposed to do if you go beyond 90 days- rip it down and start again?!)
Personally, I used 1/2″ ply for my place- 7/16″ OSB seemed too chintzy.  Am I just nuts?
They’re also offering an aluminum foil-faced plywood material, touting it as a radiant barrier to reduce the migration of solar heating from the shingles into the house if installed as a roof sheathing material with the shiny side DOWN.  Yeah, I know there’s an air gap, but isn’t the “heat mirror” facing the wrong way in this case for it to work?
Any comments on either of these materials?
  1. moltenmetal | Oct 14, 2005 02:30pm | #1
    bump
    Soultrain | Oct 14, 2005 07:20pm | #2
    Not an expert, but I think the point of the shiny side down is supposed to keep your house heat in, not solar heat out.
    1. moltenmetal | Oct 14, 2005 08:36pm | #3
      That's not what Georgia Pacific are claiming on their website- they're claiming a reduction in heat gain from solar heating of the shingles.
        Soultrain | Oct 14, 2005 09:05pm | #4
        Interesting.  My assumption would be then that if you were to peel the foil facing off (or whatever it is made of) it would be reflective on both sides.  Still it seems that you would be allowing the sheathing to heat up.
        Your right, intuition would be to put the foil side up...
      2. BillBrennen | Oct 15, 2005 01:26am | #6
        mm,What Paul said in post 6 is correct. The foil rejects radiant transmission in and out. Until the shingles can be nailed to the air 1/2" above the decking, the shiny side has to go down.Bill
        Edited 10/14/2005 7:00 pm by BillBrennen
          xxPaulCPxx | Oct 15, 2005 02:13am | #7
          The other reason for the shiney side to be down is so dust doesn't accumulate - creating a new exterior face for the heat to transfer out of through conduction (which aluminum IS good at).Rebuilding my home in Cypress, CA
          Also a CRX fanatic!
          1. BillBrennen | Oct 15, 2005 05:05am | #8
            Correct. My last post was hurried, so I omitted it.Bill
          2. moltenmetal | Oct 16, 2005 05:43pm | #9
            OK.  I see that it isn't as simple as merely reflecting any infrared that the sheathing or shingles are emitting.  If the reflective layer is buried between layers of conductive material it will simply heat up and pass the heat by conduction, eliminating the benefit of the radiant barrier. So what you're saying is that as long as the reflective layer has air on one side or the other, the radiant barrier will work.
            So:  any comments on the "exterior drywall" sheathing?  I'm seeing huge quantities of it used up here these days.  It just surprises me that nobody here even mentions it.  Is it widely used in the US too?
    xxPaulCPxx | Oct 15, 2005 12:10am | #5
    The radient barrier needs the air space.  It's actually not a mirror - it's more like a deadener.  Aluminumn foil is very poor at radiating heat back out into the air... heat gets to it and stops, it does not pass through.
    Also a CRX fanatic!
Double-Duty Large-Jaw Pliers
Klein's 10-in. plier wrench has a toothed V-jaw for grabbing pipe and conduit, or can be flipped around for a parallel, smooth grip.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
