Hairline cracks in drywall
ggillis | Posted in Construction Techniques on October 12, 2005 08:26am
Has anyone had this problem. I re-rocked the walls in my dinning room. I’ve installed hundreds of sheets of drywall and think I’m a pretty good mudder, but every seam has developed a very fine hairline crack. What’s strange is that the crack almost follows a pattern. The edge looks deckled. I know the drywall is screwed in nice and tight. I did my normal three coats of mud and this happens. Any ideas. Is there a compound I can fill it in with without having to re-tape the joint? Any help would be appreciated.
  1. marv | Oct 12, 2005 08:57pm | #1
    What kind of compound did you use for the first coat? (read what color was the bucket)   Did you use paper tape?
    You get out of life what you put into it......minus taxes.
    Marv
    1. ggillis | Oct 12, 2005 09:03pm | #2
      I used the self stick paper tape with perferated holes and Gypsum drywall compound (blue bucket)for the first two coats then topping compound (green bucket) for the last coat.
      1. marv | Oct 12, 2005 10:59pm | #3
        I think you got it backward.  Green bucket goes on first and blue bucket goes on second.  This would cause your cracks.You get out of life what you put into it......minus taxes.
        Marv
        1. sharpblade | Oct 12, 2005 11:38pm | #4
          Not necessarily true.  I know many of us think the blue stuff (Sheetrock brand Plus 3 Lightweight Joint Compound) is to be used only for the final coat, but USG recommends it for taping as well topping.
          http://usg.com/navigate.do?resource=/USG_Marketing_Content/usg.com/web_files/products/prod_details/SHEETROCK_Brand_Plus_3_Lightweight_All_Purpose_Joint_Compound.htm
          Maybe counter intuitive, but according to the maker of the product, and assuming proper application, it should work.
          This may suggest a different reason, maybe the combination of preforated paper tape (don't care for it myself) or too thick of a coat (s) without enough drying time in between => shrinking?  Don't understand what you mean by " The edge looks deckled." Is that the pattern of the holes in the paper tape? (If yes, there you go)
          If you haven't painted already, the only thing i can suggest is to enlarge the cracks with a V tool (can opener, or the carbide scribe used for scoring CBUs)and run another coat of mud  in the cracks, sand smooth...
          1. PAZ | Oct 13, 2005 12:00am | #5
            I had a similar problem on a recent job.  I used fiberglass mesh tape on the flats and paper in corners and Sheetrock plus 3 (blue bucket) for all coats.  I have used this system many times before and never had problems.  This time for some reason I got cracks coming through on some of the flat seams.   It frustrates the crap out of me because that has NEVER happened before.  I can't figure out what went wrong.   I am blaming the mesh tape I guess and from now on will only use paper.
        2. ggillis | Oct 13, 2005 12:34am | #7
          Actually you're right. I just wrote it backwards. Do you think I'll need to re tape or is there a filler product out there
          1. custombuilt | Oct 13, 2005 12:54am | #8
            You put the mud on too thick.........thin coats means THIN
            The mesh tape doesn't help much either.
            You might try to fix it by putting a coat of setting type on it.............I saw a guy fix this once by rubbing calk in and mudding over it, but I think that is a crappy fix.
             When in doubt, get a bigger hammer!
          EricPaulson | Oct 13, 2005 02:14am | #9
          Blue bucket goes in the dumpster and there should be compound under the tape not self stick glue.It's Never Too Late To Become
          What You Might Have Been
          [email protected]
  2. andybuildz | Oct 13, 2005 12:33am | #6
    I'm guessing that the adhesive from the tape got on the face side as well causing cracks from not adhering well.
  3. Jer | Oct 13, 2005 04:26am | #10
    You got your answers and they're all right.  Damn these breaktimers are good!
  4. trimnailer37 | Oct 13, 2005 06:54am | #11
    first coat= 45 or 90 setting -yeah you have to mix it but get to know it and it's worth the trouble and lack thereof afterwards.
Hole Saws That Are a Cut Above
The Spyder carbide-tipped hole saws cut quickly with a quick-release arbor that makes it easy to remove the core.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
