In rechargeables, for driving screws (or threaded fasteners generally) what functional differences exist between a drill with its hammer functiion engaged and one of the impact drivers?
Appreciate that the drill has a keyless chuck vs the quick change hex bit holder. Seems that the impact driver is more compact. For the general screwdriving/setting fasteners that I want to do is an impact driver the way to go?
Does the impact driver have something that the hammer drill doesn’t? At first glance, seems to me they both do the same thing (drive a screwdriver bit with impacts/hammer).
Hi Dunc1,
They are two totally different beasts.
The hammer drill adds a motion to the rotation of the bit in a direction parallel with the bit. The motion is kind of like a tiny reciprocating motion. which bumps the hammerdrill bit up and down slightly in the masonry which makes the drilling more efficient.
An impact driver adds an impact to the bit but in the direction that the bit turns, or perpendicular to the bit. It works kind of like a hammer knocking the driver bit and screw around thousands of times a minute.
If you tried to drive a screw with the hammerdrill set to hammer mode you couldnt do it.
An impact driver is great for driving screws except that most don't have a variable clutch. You have to kind of learn to feel the drill and screw better. The advantage of an impact is that the impact force turning in the direction of the screw helps to keep the driver bit from stripping most screws and 'camming out' it also adds a lot of force for driving large screws and small lag bolts.
Compare the inch pounds of torque between an 18 volt cordless drill and a 12 volt cordless impact driver.
Hope this helps.
Webby
Edited 9/21/2006 4:49 pm ET by webby
Edited 9/21/2006 4:54 pm ET by webby
i'll nominate this thread for publishing in the magazine as one of themost efficient threads in the history of BT,
one good question and one complete outstanding answer. We can shuter down now!;)
ditto....
We need to throw in a few of the "regulars" to make it a legitimate Breaktime thread though.... here.... I'll go first:
1. He shouldn't have hired the low bidder.
2. He should have hired a professional.
3. The illegals are ruining our country.
4. Bush sucks.
5. Clinton sucked.
6. Call a structural engineer you idiot.
7. Collar ties do not prevent walls from spreading and ridges from sagging.
There.... now it's official.View Image
how 'bout , "Either one will work as long as you don't use Piffin screws"?
Yep..... dat too.View Image
No fair! You're mixing Tavern answers with answers for the other threads!
he started tipping early...
couldn't wait..
My turn to help make this official, I don't want the this place to turn into JLC for god's sake!
1. Armins girlfriend is hot
2. Satan did not invent vinyl siding
3. Tin foil hats are now OSHA required safety gear
4. When in doubt put a pancake on it
5. If you have any questions if it's load bearing see #3
6. It doesn't matter what it is See You invented it
7. If it's important take a picture with you pointing at it
I don't have the keys to success.
I know how to pick the locks.
Thanks, I always did want to be "published" he,he. Even if it was just a thread reply.
Webby
Wooooweee! Lot of fancy talk in his reply. Did he just say that one hammers and the other twists?
"Success is not the key to happiness. Happiness is the key to success." --Albert Schweitzer
one hammers and drills and the other impacts and twists..
Actually....."impacts and DRIVES" ....that way the tool names are indeed self explanatory.
