In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Hardwood flooring
| Posted in General Discussion on June 20, 2002 01:57am
Hello,
I am going to install 3/4″ red oak in our bathroom.  Already have a plywood sub in.  Guy at Home Depot said rosin paper is not necessary at all (or anything else for that matter).  He said putting down paper was a carry-over from the old days when they installed flooring over planks.  Does installing anything (rosin, tar paper) under the oak floor buy me anything?  Thanks.  -Frank
    JDRHI | Jun 20, 2002 03:36pm | #1
    Whether its absolutely necessary or not I always put down the rosin paper. If for no other reason it keeps the hardwood from rubbing against the plywood.
    J. D. Reynolds
    Home Improvements
    "DO IT RIGHT, DO IT ONCE"
  2. andybuildz | Jun 20, 2002 04:17pm | #2
    I always put down rosin paper. Youre getting info from Home Depot....Geezzzzz!
    This house alone (see pix on my website below) I put down over 3000 sq ft of oak....sanded stained and used moisture cure finish which I think is a total necessity in water areas especially in a bathroom. I'd do at least three coats. Be careful though cause moisture cure isnt easy to work with if you havent done it before. Read all the info you can on it and follow them explicitly other wise youre in for trouble. It really is a great product in water areas....I did my whole house with it. Rosin paper is the least of it. Just do it. Separate the wood subloor from the oak. Its cheap enough. Stops a lot of squeeks where it may happen on occasion for one reason or another. Also.....I would screw down the subloor to help stop squeeks. I screwed down my entire house subfloor. I bought an auto feed type screwgun but in just a bathroom you can just use a drill with a phillips tip or a screwgun as its a small area.
    HAve fun
              Be well
                       Namaste'
                                        Andy
    It's not who's right, it's who's left ~ http://CLIFFORDRENOVATIONS.COM
  3. JAlden | Jun 20, 2002 08:07pm | #3
    Have you considered white oak? It is naturally better in moisture applications. Probably won't find it at HD.
       J.
    1. fv1 | Jun 20, 2002 08:14pm | #4
      I purchased the red oak a few months back (it was a good deal).  I am planning on putting on at least 3 or 4 coats of poly to protect it and obviously will try to keep floor dry as possible.  Have a good vent fan in the room.  Frank
    Mongo | Jun 20, 2002 08:55pm | #5
    Use red rosin or #15 felt. Don't use felt over radiant floor heating.
    Ask the guy at Home Depot if he's familiar with the installation specifications provided by the hardwood flooring association. If he claims he is, ask him why he's disregarding them.
The FHB Interview: Kohta Ueno
This building scientist offers insight and trade tools for forensic investigation
  • Cordless Drywall Cut-Out Saw
  • Podcast 461: Adding a Screened Porch, Insulating a Raised Addition, and Preventing Termites in Exterior Foam
  • Decompartmentalizing a 1940s San Francisco Home
  • Upgrade Your Window Air Conditioner
Justin Fink Deck Building Course announcement
Sign Up See all newsletters
BOOKS, DVDs, & MERCH
Shop the Store
  • 2021 Fine Homebuilding Archive
    Buy Now
    Buy Now
  • Outdoor Projects
    Buy Now
  • Tool Guide 2022
    Buy Now
  • Shop the Store
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • Issue 304 - Dec 2021/Jan 2022
    • Why You Need Blower-Door Testing
    • Passive-House Standards for Everyone
    • Window Replacement With a Side of Rot Repair
  • Issue 303 - November 2021
    • Compact Cordless Miter Saws
    • Maximize Space with Thoughtful Built-Ins
    • 10 Essentials for Quality Trim Carpentry
  • twitter
Sign Up
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
