In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
HARDWOOD FLOORING REPAIR
daholson | Posted in General Discussion on May 2, 2003 01:07am
I need to remove a strip of hardwood flooring from a prefinnished hardwood floor. Have been told to remove strip using router or skillsaw by cutting a couple of slots in the piece of wood and then removing remaining wood with a chisel. Any advice on this appreciated . What about the flooring staples?
  1. luvmuskoka | May 02, 2003 03:33am | #1
    If you can find (borrow), or buy, a Fein multi tool, that would be the ticket. If your careful you can use a plate joiner. I usually make  2 taper cuts down the middle of the board with a circular saw set at 20 or 30 deg. and pull the wedge out. The rest is hand tool work.
    At NWFA's annual convention this year a contest was held on floor board repair....with hand tools only.....the winner made a very nice repair in under 3 mins.
    Ditch
  2. dtaylor137 | May 02, 2003 05:51pm | #2
    This job is easier than one might think.
    First, make sure your skillsaw has a a blade with carbon tips. Most blades are now anyway. The carbon will cut thru any staples or nails. Be sure to set your blade depth to the thickness of the flooring only. Run two cuts the length of the piece to be removed. The two cut should be in the middle and at least 1/2" apart. Careful not to damage or cut into the adjoining pieces. Pull or gently pry out the center piece between the two cuts. If you can't get the piece out do a diagonal plunge cut thru the center strip left and pull out the pieces. Now you are left with the tongue and groove edges. Gently pry the remaining pieces away from the rest of the flooring, making sure to clear the tongue and groove before prying them out.
    To install the new piece cut out the bottom flange of the groove side. Cut the tongue and groove of the ends as well. Tuck the tongue in first and tap the piece into place use a block of pine and a rubber mallet as to not damage the finish. You can glue it in place or face nail on the groove side.
The Fine Homebuilding Interview: Emily Mottram
A Maine architect speaks about Pretty Good House and biophilic design principles that adapt to all climates.
  • Podcast 486: PRO TALK With Builder and Remodeler Mason Lord of HVP in Kent, CT
  • Get Stunning Views With Folding Glass Doors
  • Keep Craft Alive Podcast: Episode 20, Ian Schwandt, TDS Custom Construction
  • Step-by-Step Install Prehung Exterior Doors
BOOKS, DVDs, & MERCH
Shop the Store
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Outdoor Projects
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
