Hardwood Flooring with some flex?
I have a client who’d like a hardwood floor in his kitchen. He’s a professional chef and will be spending quite a bit of time there. Anyway, he’d like for the floor to have some “flex” similar to a basketball court floor. Is anyone familiar with that type of construction, or another way to achieve this? Would a typical sub-floor achieve this to any degree? It will be built on a slab and the slab can be recessed as needed. Thanks in advance for your help!
Anyone? Anyone? Bueller???
There's a good article in Wikipedia.org about this. Look it up under 'Sprung Floor'.
If you have the room you could 'spring' the floor sleepers the way that a dance floor is built for resilience. Usually this involves blocks of bridge-bearing neoprene or similar resilient material.
(my experience comes from designing a dance studio floor at an independent school where the Alvin Ailey troupe teaches in Brooklyn)
Here is a link to generic bridge-bearing neoprene products - http://www.pretread.com/bridgebearing.html
or, you can go here and buy the products specifically designed for sprung floors (safer) - http://stagestep.com/subfloors.php
System example:
System selection approach may be dictated by which assembly fits within the space you feel you can create above the slab or subfloor.
Thanks guys. This information is very helpful. I should have plenty of space, there are two steps up to the kitchen level...so, that height is more than enough to work with. Thanks again!
