Any one got any ideas on installing hardwood over a concrete slab, I know it’s far from an ideal situation but clients want ahat they want, and its hardwood, not engineered flooring.
The crew discusses finding rot when remodeling, challenges installing custom shower panels, and how to prevent subs and suppliers from sabotaging builds.
from the lumber liquidators website:
Q- Can I have a solid 3/4" hardwood glued to concrete?
You'll find some retailers will say yes. However, those that have dealt exclusively in hardwood flooring for some time will say no. In recent times some of the big box stores and adhesive manufacturers have been advocating this procedure. Only time will tell if it's a viable procedure, but it's safe to find an alternative.
Q- What kind of hardwoods can I place on concrete subfloors?
If moisture conditions are acceptable, there are three types of wood products available on concrete sub floors: engineered glue down, engineered floating floor, and 3/8 or 1/2 solid glue down. An engineered glue down is glued directly to the concrete slab. On an engineered floating floor, the tongue and groove are glued together and floated over a foam pad. Floating floors are also available in a glueless click together style. Lumber Liquidators recommends Bostik Best adhesive with the Bostik MVP (Moisture Vapor Protection) for 3/8 and 1/2 solid glue down. With Bostik Best adhesive and Bostik MVP products, a direct glue down is possible.
More traditional 3/4" solid hardwoods on concrete can be accomplished with the addition of a plywood subfloor, used as a nailing base over the concrete. However, this raises problems with door entries and other items. Overall vertical height of the new floor will increase by 1 1/2 inches. Unfinished engineered hardwood floors eliminate vertical height issues and can be stained or finished to any desires.
