I am trying to find out what size if any header I will need when adding a sliding patio door to a gabel end of my house. The house is a ranch style which uses trusses. The trusses are spaced 24″oc and the walls are framed 16″oc. The new patio door will be 6′ wide.
Rick,
Don't need one but I like a small box header to make the RO stiff.
KK
I understand part of the theory, which is that the roof loads are on the side walls, but what about the sideing and framing loads above the door? What carries those loads if there's no header?
Any exterior wall is a load bearing wall to some degree. It has to resist wind loads and dead loads.
ROT 2- 2x6 for this.
Minimum
Edited 1/13/2003 10:23:45 PM ET by piffin
Good call. Correct, as usual.
Not sure what ROT is, except it's what I find in a lot of houses. Rough Opening T___?
There has been some discussion on the forum about deleting headers in the gable walls, and the difficulty in convincing the framers to do so. So am I correct that a simple 2-2x6 thingie is a header but not a HEADER? Same question with regard to double top plates...seem to remember some discussion about not needing them in interior non-load bearing walls, and possibly gable walls.
We typically use double top plates on virtually all walls, regardless of bearing status for several reasons, the main being that inter-tying the double plates is the best way to tie interior walls together, keep them in place and ease the task of plumbing and lining. An exception being on low non-bearing knee walls at sloped ceilings, where the double plate serves no function.
piffin's right about the 2 2x6's, but I would also slip in a 1/2" plywood spacer btw the 2 so your header sits flush on the trimmers.
I wanted to thank everyone for their responses. I will plan on using a double 2x6 with a 1/2" plywood spacer.
Rick
ROT = rule of thumb
doubled 2x6 is a header
The ply is just a shim/filler.
OK, I knew what the 2-2x6 was, and I've used 1/2" ply filler...just didn't recognize ROT.
Rule of thumb 2x6 - 6 foot opening; 2x8 - 8 foot opening and so on 2X10 - 10 ft opening
Dudley, You've got it, but that's except when carrying a living space floor above it..
