In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Help Designing A Three Seasons Room
shoppit | Posted in Construction Techniques on August 29, 2004 07:14am
I’m finally getting the time to finish a three seasons room I started last year, when I built the deck and roof.  Now that I’ve found windows that I like, I ready to frame, but I still have some decisions to make.
1) There is 8’5″ from the deck to the joists above the posts.  The maximum window size is 7′, so the minimum kneewall height is 1’5″.  Although I want the maximum amount of window screen opening, 1’5″ looks pretty low.  Would I do better to make the kneewalls 2′ or 2’6″?
2) I want to put a door between the three seasons room and an attached outdoor deck that’s a step down.  I’m tempted to place the door next to the house (position A) to maximize floor space, but I’m also afraid it’s too tight a corner.  The option would be more central, next to the first post (position B).  Opinions, please?
I’m attaching a link to a bitmap that shows the layout.  If the attachment fails, it’s at:
http://shoppit.home.comcast.net/deck.bmp
Thanks for the help.
  1. shoppit | Aug 29, 2004 07:22am | #1
    Midnight postitis.  Position A is near the center of the wall and position B is against the house in my diagram.  BTW, when I viewed the bitmap using IE6, it appears chopped up when it first opens, but fills in when enlarged.
  2. MojoMan | Aug 29, 2004 01:59pm | #2
    How high above grade is the deck? You might need 36" kneewalls so someone falling through the screen can't fall off the deck.
    Al Mollitor, Sharon MA
  3. Piffin | Aug 29, 2004 03:15pm | #3
    probably position A for the door.
    if the glass is less than 18" above the floor, you need tempered glass for many codes and insurance satisfaction. you mention 15" which seems to be to framed RO so the glass itself might just be high enough to get by. Check that out carefully
    1. shoppit | Aug 30, 2004 05:23am | #4
      The deck is 30" above grade.  The windows have four sashes on four tracks, plus a screen.
      1. Piffin | Aug 30, 2004 05:36am | #5
        i'm talking about distance from bottom of glass to floor - interior
        but in regards to the additional info - a deck that high off ground needs a railing.
        1. shoppit | Aug 30, 2004 05:56am | #6
          Actually, the windows use a clear vinyl, not glass.  The sash frame width is about a coupe inches, so the distance from the deck to the window will really be determined by the kneewall height I choose.
          1. FastEddie1 | Aug 30, 2004 07:22am | #7
            Where did you find the windows?Whenever you are asked if you can do a job, tell'em "Certainly, I can!"  Then get busy and find out how to do it.  T. Roosevelt
Fastener System for Solving Deck Fascia Board Expansion
A special drill bit and color-matched fasteners lets composite or PVC deck fascia boards expand and contract to minimize warping.
  • Podcast 487: Cedar Closets, Conditioning a Woodshop, and Regional Construction Jargon
  • Podcast 487: Members-only Aftershow
  • Festool's Domino: Worth the Dough?
  • Podcast 486: PRO TALK With Builder and Remodeler Mason Lord of HVP in Kent, CT
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
  • Outdoor Projects
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
