Help me settle a debate about hanging a cabinet please!
PeteM | Posted in Construction Techniques on November 30, 2010 09:38am
Ok, the preface- I’m a nurse manager but quite competent with tools. I’m not a pro.
Last week on my hospital unit a cabinet fell off the wall after being installed 2-3 years ago. I looked at the wall and cabinet afterward and could not believe it. The wall is sheetrock over old tile, and apparently has a masonry wall behind that. A cabinet about 4-5 feet wide was hung on 4 pieces of 1/2 in plywood with some drywall screws. The plywood was fastened to the wall with construction adhesive and masonry nails. The top 2 pieces of plywood let go first, then the screws ripped out of the bottom 2 pieces. One of the screw heads pulled thru the back of the cabinet. If anyone was at the desk below they would have been injured. It seemed obvious to me this was poor workmanship.
However, when we called the contractor back to fix it, the guy insisted to me that the only problem here was that nails were used instead of screws into the wall. To me that’s only 1 issue of many. How should this have been done?
Appreciate your input.
  1. DanH | Nov 30, 2010 10:08pm | #1
    As another non-pro, the anchorage to the wall should have been toggle bolts or something of equivalent reliability & pull-out resistance.  Simple nails or screws are not sufficient (though special masonry screws would be fine if properly installed).
    And a half-inch piece of plywood is just barely enough "meat" to hold the screws from the cabinet, but only if the screws can penetrate through about 3/4", which they can't because there's tile behind the drywall.
    And, as Piffin will tell you, drywall screws should not be used to secure a heavy cabinet.  "Structural" screws (such as GRK cabinet screws) should be used.
    As to how it probably should have been done -- anchor the plywood to the wall better, hang the cabinet, then, along the top inside the cabinet, install several more fasteners (toggle bolts, wedge bolts, masonry screws, etc) that go through into the masonry.  And a couple of such fasteners near the bottom wouldn't hurt.
    Or use cabinet hangers that come in mating halves -- anchor one half to the wall and the other half to the cabinet, then hang the cabinet and install a few lighter screws into the plywood just to hold the cabinet snug to the wall.
      xxPaulCPxx | Dec 01, 2010 12:03pm | #2
      That 2 part system DanH is reffering to is called a "French Cleat".  It has two long boards nearly the width of the cabinet.  Each board has an angle cut in one edge, like a 45 degree angle chopping off one corner.  On board is mounted to the wall and the other is mounted to the cabinet.  They are mounted so that when the board on the cabinet is set down on the board to the wall, both cut angles meet.  The one on the wall slopes to the wall, so the assemble is pinned to the wall and supported across it's whole length.  It's also level, presuming both boards were mounted level to the wall and to the cabinet.
  2. Piffin | Dec 01, 2010 05:33pm | #3
    My ears were burning
    I rail against using drywall screws for cabinets so much on these forums that the guys have renamed the brittle little things "Piffin screws"
    But
    It sounds like the primary failure here was in the ply to SR adhesive. A well adhered backer would never part from the SR
    I do question tho whether it was the adhesive to paint or the pain to SR bond that actually failed.
    Were I doing an install of this type, i would use 3/4" pine or poplar, PL Premium Construction adhesive, and the GRK caliburn concrete fasteners or Tapcons for the mechanical attachment., Then structural cabinet screws to hook the cabinet to the track mount.
    The described attachment is below my standards, but is extremely common, othere than the nails instead of screw or toggler type concrete fasteners. That detail is indeed, unprofessional, IMO
    Jeff_Clarke | Dec 02, 2010 08:32am | #4
    The failure as noted was due to the use of masonry nails.   Tapcons or other appropriate masonry anchors would have kept the plywood on the wall.
    For cabinets, I really like the Fastcap system - http://www.fastcap.com/estore/pc/PowerHead-Screws-c11.htm  because the screws have 1/2" diameter heads (which get concealed) - see photo.
    For heavier-use cabinets, I like to see a full 1/2" plywood back so that it can be fastened anywhere.
  4. sapwood | Dec 02, 2010 11:55am | #5
    If only...
    "... the guy insisted to me that the only problem here was that nails were used instead of screws into the wall."
    Key to your discussion with him is his use of the word: only. There is a huge difference between the pullout resistance of screws and nails. He made a big mistake there and seems to be choosing his words to minimize it.
    Ever try to use a claw hammer to pull a screw out of a board?
Solar Shingles in Austin
A Tesla roof powers this five-bedroom Texas home and then transfers extra energy to the power grid.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
