Help on Prehung Doors #2
glennh | Posted in Construction Techniques on May 20, 2007 07:50am
Thanks for your replies. This list is great. I don’t post very often but get alot of good
answers whenever I do. Just what an inexperienced person like myself needs.
Consensus seems to be to wait til the flooring is in before I trim doors and finish them.
My home is southwest style and I’m not casing at all. Just using kerfed jambs with
bullnose drywall corners into the kerf. No baseboards (ok: I know I’ll need something
around the wood but it will be minimal).
I probably will try to cut the pocket doors ahead of flooring. The bullnose corner sits
abit high and intrudes slightly on the opening size making it more difficult to remove
the door after its installed.
Any ideas as to what might be a good wood flooring to lay over a concrete slab and
whether or not to use a pad? I’ve looked at Kahrs but that seems pretty expensive.
Thanks………..Glenn
  1. rez | May 22, 2007 07:44pm | #1
    Greetings glennh,
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
    Perhaps it will catch someone's attention that can help you with advice.
    Cheers
    The owner of the axe, as he released his hold on it, said that it was the apple of his eye; but I returned it sharper than I received it. It was a pleasant hillside where I worked, covered with pine woods, through which I looked out on the pond, and a small open field in the woods where pines and hickories were springing up.
    -Thoreau's Walden
  2. SBerruezo | May 24, 2007 05:21am | #2
    bump
  3. rez | Jun 02, 2007 08:25pm | #3
    In the event you fail to receive the information you requested you may be able to find it in the achive listing of old threads on Breaktime.
    If you scroll up in the upper left corner of your screen there is an advanced search function that will take you to a page of instructions directing you to previous threads dealing with whatever you type in the search bar.
    If you type in 'pocket doors', 'bullnose', 'wood fdloor pad'  or other keywords of the subject matter you'll get a supply of data from those old threads.
    Cheers
    There was a stove, a bed, and a place to sit, an infant in the house where it was born, a silk parasol, gilt-framed looking-glass, and a patent new coffee-mill nailed to an oak sapling, all told. The bargain was soon concluded, for James had in the meanwhile returned.    -Thoreau's Walden
Fine Homebuilding – July 2023, Issue #316
Find online articles on timber-framed solar canopies; the right footings; the best toilets; choosing insulation; compact cordless routers; and much more.
  • Podcast 569: Bath Fan Installs, Sunroom Trim, and Basement Control Layers
  • Podcast 569: Members-only Aftershow — Rob Yagid’s Addition
  • Fine Homebuilding – July 2023, Issue #316
  • Fine Homebuilding Issue #316 Online Highlights
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 316 - July
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
