Help! Removing linoleum from wood floor
| Posted in Construction Techniques on January 12, 2003 10:42am
My wife and I bought an old farmhouse with simple wood floors (5″ or so t&g) that she’d like to paint.  The only problem is the linoleum floor covering is STUCK.  Putty knives and razor blades will pop up little inch square pieces… it’s not glued down, looks like tar paper that melted down from the southern exposure.  Anybody got a better way?  I’m looking at way too many labor hours this way.
  1. CAGIV | Jan 12, 2003 11:26pm | #1
    Lot people here have suggested using dry ice to crack the bond?
    1. DaveRicheson | Jan 13, 2003 01:05am | #2
      Or go to the other extreme, use a heat gun to soften the material. BTW if the flooring is really old it may contain asbestos, so use appropriate measures to ensure yor family's safety.
  2. MIKEBUETTNER | Jan 13, 2003 04:33am | #3
    You might want to have it tested for asbestos... if that sort of thing concerns you.
    bit
  3. 92588 | Jan 13, 2003 05:22am | #4
    knee pads and 3 inch knife keep humming
    1. mitch | Jan 13, 2003 05:38am | #5
      my wife and i ran into the same problem in our last house- the hideous pink linoleum probably went down over the oak sometime in the 1940's or 50's- the glue turned out to be water soluble.  with some hot wet towels and a putty knife it came up virtually spotless!  good luck!
      m
Achieve a Flat Drywall Finish
These products and methods result in the clean lines essential to a midcentury-modern aesthetic.
  • Podcast 569: Bath Fan Installs, Sunroom Trim, and Basement Control Layers
  • Podcast 569: Members-only Aftershow — Rob Yagid’s Addition
  • Fine Homebuilding – July 2023, Issue #316
  • Fine Homebuilding Issue #316 Online Highlights
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 316 - July
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
