Help with Curved Wall
MBaybut | Posted in Construction Techniques on November 25, 2008 06:21am
Hi,
I’m planning on building a patio with one side having a curved 24″ high wall and I have a couple of questions,
1) How do I lay out the Arc line.
2) How should I do the cap.
3) Not had the slab poured yet but should it follow the intended arc or just get it oblong and lay out on top of it.
All help appreciated,
Mike
  1. AitchKay | Nov 25, 2008 06:44pm | #1
    I built a serpentine retaining wall last year that was about 90' long.
    I used a 1x4 as a trammel to lay out the curves.
    I drilled a hole in the end of the board to receive a funnel, and several holes the size of my form stakes along the length of the board for various different radii.
    To use my layout jig, I stuck my funnel into the end of the board, filled it with flour, and pivoted the board while tapping it with my hammer.
    The customer and I stepped back, looked at it, and where he wanted to make changes, I erased the line with a lawnmower.
    When we were satisfied, I made the line permanent for the excavator with paint.
    I don't know exactly what you're doing, but you probably want a curved slab. Use the center-pivot technique above, skip the flour, and locate form stakes (these are usually about 3/4" dia. x 2' long) directly off of the pivot board. Bend your form wood around these stakes. If you have a tight radius, multiple strips of 1/4" tempered Masonite work well.
    If the slab will not be visible, you're ready to pour -- maybe grease your stakes so that the concrete won't stick. The notches left by the stakes won't ever be seen.
    If your slab will be exposed, now go back and drive wood stakes on the OUTSIDE of the form, screw your form boards to these, and then remove the metal stakes.
    AitchKay
Mortar for Old Masonry
  • A Closer Look at Smart Water Leak Detection Systems
