…After pricing the 1/2″x1/2″x 18′ laminations(450 of them), at a cost of$5500.00 PLUS glue(epoxy) at$1500.00!!!!, onwards to plan B, which is now a segmented glue up with 1’2″ thick veneer slices mitred on the bottom face, with varying-pitch blocks to align the subsequent blocks to end up with plumb outer and inner faces.This willend up with the inner and lower faces seen with the other two hidden.Should be easier.
By considering things like energy-efficient mechanicals, window orientation, and renewable energy sources, homes can be evaluated to meet the energy codes. Here's what the IRC has to say.
...After pricing the 1/2"x1/2"x 18' laminations(450 of them), at a cost of$5500.00 PLUS glue(epoxy) at$1500.00!!!!, onwards to plan B, which is now a segmented glue up with 1'2" thick veneer slices mitred on the bottom face, with varying-pitch blocks to align the subsequent blocks to end up with plumb outer and inner faces.This willend up with the inner and lower faces seen with the other two hidden.Should be easier.
