So, I pulled down the old plaster on lathe system (or did it fall) and now am left with dark, ugly beams with a rough surface that has become an ideal surface for spiders to construct large and intricate webs.
While I appreciate their fly-catching properties, I’d rather have something a bit classier. I’d like to keep the look of exposed beams but sure would like a more attractive look (and one easier to keep clean).
Should I try to cover the rough surface with some kind of paint? Is there a way of sanding the beams down that’s easy and not too messy?
Or is it easier to just buy some finishing lumber and hide them completely?
Painting would depend on the quality of the wood - will it look good when you're done? Is it all cracked, crazed, and twisted? Old wood will soak up a lot of paint, so use a primer/sealer first. If you paint a light color, it should brighten things up considerably.
I opted for cedar tongue&groove over my old beams - 3/16 inch planing nailed parallel to the beams. It came out looking pretty nice and I still have the "natural wood look."
While I appreciate their fly-catching properties, I'd rather have something a bit classier. I'd like to keep the look of exposed beams but sure would like a more attractive look (and one easier to keep clean).
Should I try to cover the rough surface with some kind of paint? Is there a way of sanding the beams down that's easy and not too messy?
Flossie, tough question over the net... are the beams sawn, with many rough fibers; or hewn with scalloped surfaces? What is your choice for ceiling now that the plaster/lathe is down?
More information, more answers.
