Home addition results in existing roof rafters cut back behind the heel plumb line
user-927220 | Posted in General Discussion on July 20, 2018 12:13pm
 Hey fellow builders!
The guys helping me with an exterior porch addition did some blind cutting on my existing rafters. As a result, the cuts were made higher up the rafter board above the heel plumb line leaving very little heel left on the top plate in a few cases. 3 pictures are attached below.
1) Should this be fixed?
2) What’s the best fix? Hurrican Simpson ties? Sister on a 2 ft boards of the same dimensions with the correct heel plumb lines and nail them solid to the existing rafters?
Thanks in advance!
AL Backpacker
  1. oldhand | Jul 20, 2018 07:24pm | #1
    wow!
    I don't see any pics. But if there isn't some part of the heel on the plate expect catastrophic roof failure. With out pics or more info  more than that is hard to guess. The sistering soution depends on how much load is involved and if this will get inspected. And more.
    1. calvin | Jul 22, 2018 02:49pm | #2
      Old, got the pics up
      hope it helps.
      1. oldhand | Jul 23, 2018 04:55pm | #3
        Ow!
        Well the pics are descriptive allright.  That's a mess for sure.  Seems like the minimum bearing for a floor joist is 3/4" though i've never felt good with less than 1". I don't know the minimum for a rafter but it certainly would be no less. Hurricane [rafter]  ties would hold it from uplifting better than 2 toenails ever did but they are required to be on the outside of the wall.
        If the roof load isn't large [long rafter span] maybe scabbing onto the sides of the rafter would hold the load but I sure don't know that for a fact. If this job is inspection required that's a whole 'nother issue. Sorry I couldn't help here, good luck.
  2. cussnu2 | Jul 24, 2018 10:46am | #4
    If it were me, I would be looking to my local machine shop/steel fabricator to bend some 14 gauge brackets that you could attach to the back of the top plates and the bottom of each rafter.  You could ask an engineer if that would suffice but my estimation would be 14 gauge would be more than enough.  If you jump up to 1/8th inch, I am sure it would work but I am think they would have to cut and weld that up in which case they could also weld small gussets on one side which would insure it never goes anywhere.
  3. mgmahan | Jul 26, 2018 10:59am | #5
    Rim
    I'm assuming you don't want to remove any sheathing or ceiling. If you have enough bearing to keep the rafters from falling off while you are working, remove the wedge shaped pieces and add a 2x rim. Before you install the rim attach a joist hanger for each rafter. Pound the rim on so that the joist hangers slip under the rafters. Bolt through the rim with lags into the end of each rafter.
    Mike Mahan
Hole Saws That Are a Cut Above
The Spyder carbide-tipped hole saws cut quickly with a quick-release arbor that makes it easy to remove the core.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
