Hot Water Heaters in Series
Waterbear | Posted in General Discussion on August 5, 2006 04:39am
My plumber said he’s been installing a lot of setups with (2) 40 gal. heaters in series.
His rationale is:
40 gals are so cheap,
he runs one on vacation setting and the other super hot, and somehow maintains there’s an enrgy savings there over a traditional 80 gal,
if one ever gives out you still would have hot water.
I remember reading something in JLC (I think) about recent concerns over water heaters kept too low and breeding a bacteria, but he thinks the second tank would eliminate this posssibility.
Have any of you run across this recently?
  1. dgbldr | Aug 05, 2006 04:50am | #1
    Yes, I've seen it done.  No I haven't seen it done with one lukewarm and one superhot.  They were both set to normal temp and worked very well.  No energy savings, because 2 heaters have more surface area than an 80-gal so lose more heat. Just cheaper to buy.
    Don't know about bacteria, but superhot in one tank is a scalding hazard.
    DG/Builder
  2. plumbbill | Aug 05, 2006 04:58am | #2
    I do a lot of multiple tank systems, but about 95% of them are in paralell.
    Reason is more for volume output verses how much hot water storage.
    A lower temp water heater can breed bacteria in an unpure water condition, which a second tank set less than 150 degrees will not kill.
    Unless your system sits idle for very long periods you really don't have much to worry about.
    Yes you will have hot water if one tank fails, but on a series system if one fails you will have 40 gallons of storage that is not heating. No problem if it's the first tank, but if the second tank fails you need to have a circ pump on the system to maintain temp when in idle conditions.
    Liberals thank those that beg for peace. Conservatives honor those that fought for freedoms. BDW
  3. WayneL5 | Aug 05, 2006 05:00am | #3
    Would not be an energy savings, probably waste energy because, like the other poster said, you've substantially increased your surface area.
    Bacteria are becoming recognized as a problem.  Canada, I believe, has codes specifying minimum temperatures for water heaters.  It's around 140°F, I believe.  Anyone who knows can correct me.  Having two water heaters won't protect against this because when you have heavy usage you just draw the contaminated water through the other water heater so fast the unit can't heat it up to a level that will disinfect it.
    As for one giving out, if it's the hotter one you guarantee you are getting contaminated water.  Besides, if the heater gives out you can install another the same day or the next.  Even a few days without hot water is no big deal.
    1. JimB | Aug 05, 2006 04:52pm | #4
      I don't know about the Canadian code, but Legionella is more apt to grow in hot water systems where the temperature is less than 140.  Water temp is only one risk factor for Legionella growth, of course.
      1. rjw2 | Aug 05, 2006 05:04pm | #5
        A quick google searh is showing recommendations in Canada (Quebec) of 140 F (60 C).
        That high of a temp is a potential scald hazard, though especially for kids.
        So the solution mis run it hot BUT install tempering valves.
        http://www.hydroquebec.com/advice_hot_water/index.html
    2. sledgehammer | Aug 06, 2006 04:07am | #12
      If bacteria growth is a concern on vacation setting... shouldn't I be concerned with bad bugs growing in my cold water?
      1. plumbbill | Aug 06, 2006 04:19am | #13
        Not really.
        A few things
        1. you need bad water to begin with
        2. remember highschool science & petre dishes
        3. you need some oxygen in the mix.
        If I was leaving a cabin for a long time & shut off the WH I would give it a good flush when I got back to the cabin, same with the cold water too."can you cross your legs were short a nail" Pontius Pilate
      2. WayneL5 | Aug 06, 2006 05:26pm | #16
        No.  The optimum temperature for the growth of the organisms in question is over 100°F.
  4. rjw2 | Aug 05, 2006 05:06pm | #6
    He might be interested to know that plumbers have been held liable for damamges for scald injuries when they leave a water heater set too high.
    Maybe it makes sense, maybe not, but that is the reality.
    1. JimB | Aug 05, 2006 06:40pm | #8
      Absolutely, 140 degrees is a scald hazard.  Not just kids, either.  Elderly folks are more apt to be scalded because they don't sense the high temp as quickly.  As you suggest, I wouldn't set the heater temp that high with out tempering valves.
      1. rjw2 | Aug 05, 2006 07:09pm | #9
        Temp
        Exposure Time For a Third Degree Burns (The most serious)
        160
        Less than 1 second
        155
        1 second
        148
        2 seconds
        140
        5 seconds
        133
        15 seconds
        127
        1 minute
        124
        3 minutes
        120
        5 Minutes
    BillHartmann | Aug 05, 2006 06:40pm | #7
    If I am not mistaken, Vacation setting just inhibits the main burner, but keeps the pilot going.
    I don't see anything to be gained except for the extra fees to the plumber.
    And 80 gal is not that common.
    Much more common would be 50 gal and if it is a high recovery rate then it can produce even more HW.
    Edited 8/5/2006 11:42 am by BillHartmann
    1. BryanSayer | Aug 06, 2006 07:44am | #14
      85 gal. doesn't seem uncommon, at least in gas. I had one installed at our house.
  6. Scott | Aug 05, 2006 08:42pm | #10
    Another reason to use parallel rather than series is that it balances the load. In a series arrangment one heater is working hard (the first one) while the second one only has to work if the first is exhausted.
    If you go with parallel, try to equalize the outlet pipe lengths so that water is drawn equally from the tanks.
    Scott.
    Always remember those first immortal words that Adam said to Eve, “You’d better stand back, I don’t know how big this thing’s going to get.”
    1. mike585 | Aug 05, 2006 09:58pm | #11
      There really is no good reason to put heaters in series. Put them in parallel and forget about it.
       "With every mistake we must surely be learning"
  7. PhillGiles | Aug 06, 2006 08:10am | #15
    40 gal electric water-heaters with set-back thermostats in front of 60 gal gas units are what I see a lot in homes with multiple teenagers.  The electric unit goes on  early in the morning and ensures that there's enough for everyone in the family to get a shower, goes off at 8 or 9, and then may come back on for dinner or bed (it can be manually triggered for special occassions).
    Phill Giles
    The Unionville Woodwright
  8. renosteinke | Aug 06, 2006 05:49pm | #17
    Oddly enough, I've seen a few such systems installed. The main difference from what you describe is that the second heater usually wasn't identical to the first one.
    The second heater was usually called a "booster" heater, and was intended to deliver a lot of heat, fast.
    Your heat losses are related to, among other things, the temperature difference to the inside of the tank, and the outside. This is an exponential relationship; double the temp diff, and you have four times the loss.
    There is also the matter of mixing the hot and cold water. I think, given a choice, I'd rather raise the temp in stages, rather than in one big step.
    I suppose I can imagine two situations where this "series" arrangement would really shine: "point of use" and "loop" systems.
    "Point of use" being where the second heater is close to the final user.
    "Loop" being where water is constantly circulated, so as to reduce the wait for hot water to arrive at the faucet.
    Which system you choose probably depends on what problem you're trying to solve. As I see it... everything being equal... "parallel" gives you more hot water available, while "series" gives you a quicker recovery time.
PVC for a Rot-Proof Fence
Built with rot-proof material with traditional tools and techniques, this classic border is engineered to never sag.
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
