In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
House getting cold please help
Nick25 | Posted in General Discussion on October 16, 2005 04:29am
I’ve done a major reno on my home the past 8 mo’s. I had a new furnace installed and I know it runs. I had to remove the thermostat to hang drywall I’m not sure what I did but I’m not gettin the thing to turn on. My suspicion is that I’ve rewired the thermostat wrong. Can anyone tell me how to go about wiring a thermostat
    maddog3 | Oct 16, 2005 05:32pm | #1
    ....go look at the terminal strip on the furnace ....and match colors to letters on the stat"......just be sure the furnace power is off or you could blow a fuse and or damage the circuit board
    ...was the power off when you disconnected the stat?
    ....is there power to the furnace?
    Edited 10/16/2005 10:37 am by maddog3
    1. Nick25 | Oct 16, 2005 07:55pm | #2
      Thanks for your reply, the furnace was off all summer. So I'll assume I didn't wreck anything. Any reccomendations for a thermostat. I just would like a programable on so I can save a little on heat. I appreciate your input. Nick
      1. WayneL5 | Oct 16, 2005 08:24pm | #3
        I like the Carrier programmable thermostats because they don't require any batteries.  Some of the battery powered ones will stop working when the battery dies and you'll loose heat.  If that happens when you are not home in the winter it can be trouble.
        The Carrier's require one additional wire so unless you have a spare you'll have to run new wiring between the thermostat and the furnace.
        maddog3 | Oct 16, 2005 08:43pm | #4
        ...well if you are home throughout the day a programmable stat won't save you too much, they do offer flexibility for a seven day schedule however.
        I would suggest you talk to an HVAC supplier rather than the big box alternative, as they would be more helpful with any connection or "ease" of programming questions.
        As for what make....
        I have no preference, I install what has been spec'd and never fiddle with them for fear I will break the darn things as another suggestion, try talking to your Gas Utility and ask if they have any "programs" or rebates for your efforts in conserving energy"
        1. Nick25 | Oct 17, 2005 01:30pm | #5
          O.k the furnace is up and running, I've got some idea's for thermostats from and old finehomebuilding I guess I'm ready for winter. Thanks for your help.
            aimless | Oct 18, 2005 01:30am | #6
            You may have already bought your new thermostat, so this is probably a moot point. We've had a programmable thermostat from Lux for 7 years and it works just fine. The thing came with instructions so that even I could install it - it was inexpensive and is battery operated. I think I've replaced the batteries once.
          2. Nick25 | Oct 18, 2005 04:15am | #7
            have not bought the 'stat' yet so I thankyou for your input.
Industry-First Cordless Rebar Cutter and Bender
A brushless motor and 36v batteries power Metabo HPT’s cordless rebar bender and cutter.
  • Keep Craft Alive Podcast: Episode 20, Ian Schwandt, TDS Custom Construction
  • Installing Prehung Exterior Doors
  • Podcast 485: Air-Sealing a Mobile Home, Owner/Builder Tests, and Ready-to-Tile Shower Bases
  • Podcast 485: Members-only Aftershow
BOOKS, DVDs, & MERCH
Shop the Store
  • Outdoor Projects
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
