I put a coat of “Fresh Start” primer on #2 pine or common pine which ever you wanna call it. Now my paint, which is Benjamin Moore which I usually use, was matched to a certain color. The guy working the counter did not do anything out of the ordinary. I have been using the same supplier for a while but this guy was next to another store I was already in and I found it convenient. I do have to mention he was also a Benjamin Moore dealer. Anyway, after the Fresh Start, I applied one coat of this semi-gloss “burgundy” and then another and another. Tomorrow morning I will be on the fourth coat. I have been painting for quite a while and have never ran into this problem before. I am not sure I want to blame the guy at the paint store because I was only covering primer on fresh wood. Has anyone ever encountered this problem with semi-gloss on primer? Is there something I’m missing?
Thanks for the info!!
First - I'm not a painter - but I know good results when I see them, and have been around painter's enough and have hired enough to have learned a few things. First, when using a dark top dark coat, like burgundy, often, a tinted primer is used. Secondly, painter's generally use multipliers when figuring the price for such a paint job...
Edited 2/7/2004 9:12:59 PM ET by DIRISHINME
I can only think of one thing that the wood was not dried enough and the acids in the pine are still bleeding through but it's not just over the knots. I dunno!
wrong brush?
Are you telling me that .99 cent brush from the bargain bin at Home Depot isnt gonna work? Momma always told me to be a bargain shopper.........Please gimme some credit" Looks good from my house!!"
try a paint pad..they work miracles..
I cant really see that working much better. I do use a Purdy brush for latex paint, have always used Purdy or Wooster and have never ran into this before. I can only think of the acids in the wood. I hope I didnt offend you about the brush question. I wasnt sure if you were being sarcastic. Thanks for your input.
The pads sometimes work for painting against trim like doorways and stuff but I'll stick with the brush work. " Looks good from my house!!"
Burgandy is a red colour.
Reds do not have as much pigment for coverage. You need to use a tinted or black primer plus two or three coats, or as many coats as needed to cover when using reds
Taunton University of Knowledge
FHB Campus at Breaktime.
where
definately makes sense now that I think back to a previous job with a red primer and a gloss black finish
Thanks for pointing that out and reminding me
Dip the brush in the can more often!!!!
When you are putting on a dark color you can't skimp on paint!
Lay it on nice and thick.
It is not gonna cover until you build up a certain film thickness.
You can put on 8 thin coats or 2-3 real coats.
Mr T
Do not try this at home!
Remodeling Lead Carpenter w/ 20 years exp.
+ A Construction Engineering Degree
Burgandy should have covered easily with any ones paint.
Sounds like the guts got left out of this can . Trade it in for another with a much different run number.
Tim Mooney
I could not find anywhere a description of the reason you are repainting. Is there sap bleeding through the paint? Is the painted surface not the correct color? Can you be more specific?
I painted a room in my house burgundy and it took 4 coats! NEVER AGAIN!!!Looks good though!
Coming to you from beautiful Richmond, Va.
See my post msg#39803.3 in the topic Estimating Traps
ParadigmProjects.com | Paradigm-360.com | Mac4Construction.com
shoemaker,What is the wood doing?Bleeding,flashing,what?I allways used an enamel undercoater tinted to about 3/4 color you are using,sand and then 2 occaisionaly 3 coats finish.If the knots are bleeding through..shellac them first then prime with undercoater.SGB oil/alkyd paint
The problem is most likely the color. While there may be some other factors (such as spread rate, poor quality applicators, etc), I would bet money that the problem lies in the color. As was previously stated, many deep/dark/or vivid colors have very poor hide.
