How stupid was I?
RichBeckman | Posted in General Discussion on April 18, 2007 04:34am
No, no. I don’t mean in general! I already know the answer to that!
A while back I was replacing a powered attic exhaust fan. But I forgot to have the customer turn off the power and I had no way to enter the house.
So I very carefully removed the wirenuts and deliberately shorted the hot to the neutral to throw the breaker.
So, how stupid was that??
Rich Beckman
This signature line intentionally left blank.
  1. DK | Apr 18, 2007 04:42am | #1
    Do it all the time at least you know the breaker works! and it's also a sure fire way to figure out which breaker is which in the future. DAN
      maddog3 | Apr 18, 2007 12:49pm | #16
      you folks have been lucky that's all...lucky that the breaker worked
      ...lucky that the grounds were all tied together
      ....lucky that you didn't start a fire,it always amazes me how far people will go when it comes to electricity in a house....like the jokers that get their kicks using their fingers to check for live circuits...most here will claim that it ain't rocket science anyway.....but foks will simply keep doing this stuff until something goes wrong and then they will probably want to sue the Mfrs. for selling defective equipment..anyone who trusts a CB to perform flawlessly 100% of the time is naive, to say the least...lucky, just plain lucky.
      ., wer ist jetzt der Idiot ?
      1. MVAgusta | Apr 18, 2007 01:01pm | #17
        The knob-and-tube circuit in my house was on two separate 20 amp breakers, you could short the wires forever and not trip either of them. Not knowing this for a year or so of living here, I moved one of the breakers in question and wound up with 240v across the basement lighting. Immediate darkness.
          maddog3 | Apr 19, 2007 03:30am | #24
          well there ya go....!.
            SamT | Apr 19, 2007 05:05am | #39
            That sounds somehow familiar (|:>)SamT
            There are three kinds of people: Predaters, Prey, and Paladins. The really strange thing is that Prey feels safer from Predators by disarming Paladins.
        SamT | Apr 19, 2007 02:18am | #20
        ...lucky that the breaker worked ...lucky that the grounds were all tied together....lucky that you didn't start a fire,
        Lucky the breaker worked? That's what they're designed to do. It's not luck that caused it to work, it was engineeering. It would have been against strong odds if it was one of the rare breakers that didn't work. And if it didn't work, the most common response after trying to forde trip a breaker is to short the wires again to see if it worked.
        Lucky the grounds were all tied together? you mean the odds are that they weren't? And if they were in fact not installed as normally done, Rich would have said, "Hey! how come no spark? There was supposed to be an earth shattering spark!"
        Lucky he didn't start a fire? In order for a fire to have started somewhere the conditions to be met would be that one of the two wires had a high resistance spot in it. Higher than the point contact made when just touching two wires together .Then the heat generated over the few milliseconds of sparking contact would have had to have been immediately transfered to a readily flammable fuel rather than back along the copperof the wire itself. This could only occur if the bad spot in the wire was in close contact with the fuel.Finally, if those conditions existed the fire would be much more likely to occur after the equipment was energised and applied a long term load on that high resistance spot so rapidly buring the wire in two probably saved the house from burning down.
        Given the odds that the wires would continue to work as they had been for years are1:357,284,289.7 vs the odds of 1:25 that Rich would be seriously injured or killed. . . .
        Only someone whose retirement plan is winning the largest Powerball in history would choose not to force the breaker.
         SamT
          maddog3 | Apr 19, 2007 04:04am | #31
          well I don't play Powerball, and I resent your insult .
          you give the impression that no one but you and a few others here know a wire has two ends... and the but since I do this for a living, over the past four decades I've seen too many incidents of guys burning their Kleins up, or welding the ends of pipe cutting into wires they figured were dead since they pulled this stunt, ....it's a dangerous trick that most folks seem to enjoy performing...I ain't one of them, nor are the other electricians I work around, granted, there is the occasional cowboy but once they see the light they quit doing itif folks want to assume that the wiring is correct and proper, ....something that more than a few homes do not have..
          go ahead knock yourself out..I would re-tell a story about a young man who lost his life standing on some switchgear when there was a fault and the breaker never tripped..but I don't want to waste your timejust don't try to convince me that ALL breakers work ALL the time because they don't.so yeah, Rich and others are lucky.
          1. hvtrimguy | Apr 20, 2007 05:39am | #56
            I'm with you maddog, I was working on a job installing a kitchen where a week or so later an electrician's helper died when he went down to the damp basement to do some work. not sure what exactly happened but I'm sure he wasn't expecting it. Electricity is more complicated than people think it is. seen a melted panel box on another job once. wasn't pretty."it aint the work I mind,
            It's the feeling of falling further behind."Bozini Latini
            maddog3 | Apr 20, 2007 12:39pm | #57
            he most likely used a live wire to scratch off the numbers on his Lotto ticket ....
            SamT | Apr 20, 2007 02:55pm | #58
            LOL
            Touche'SamT
            maddog3 | Apr 21, 2007 03:23am | #59
            yes, let's move on.
          5. sledgehammer | Apr 21, 2007 05:15am | #60
            Customer not home... can't get in to turn off power.
            I'd short it out in a heartbeat and with my luck the circuit would also be tied to a freezer full of food, a sump pump and the garage door opener that the customer uses as their sole means of entry.
        2. grpphoto | Apr 19, 2007 04:25am | #33
          > Lucky the breaker worked? That's what they're designed to do. So? My last house had a load panel in it with six breakers. Five of them would not trip under any circumstances. I didn't test the ones in the main panel (which was older). I just replaced it.He's lucky the breaker worked. Sometimes they don't.George Patterson, Patterson Handyman Service
            Troublemaker | Apr 19, 2007 04:28am | #35
            I do it all the Time!
                You think I would pay for this hair style......
  2. brownbagg | Apr 18, 2007 04:43am | #2
    I do it all the time., i have change out complete ballast system hot, just so I can see while doing it.
    i do live in Alabama, so my advice might be worthless
    PaulBinCT | Apr 18, 2007 04:45am | #3
    Mr. "Electro" Hartmann will undoubtedly be here soon to chastice you properly but I'd say semi to soft-boiled stupid.
    If the wiring you used as your instant breaker tracer was light gauge you could've gotten hurt or permanently damaged the wiring and wound up buying a new fan for your clients.
    PaulB
      BillHartmann | Apr 18, 2007 05:06am | #8
      Actually depending on the type of materials and how much room that you had to work it might have been safer to just change it hot than to force trip it..
        PaulBinCT | Apr 18, 2007 05:29am | #9
        BILL!!!
        I'm ... "shocked". Next you'll be condoning buried j-boxes ;)
         PaulB
        1. roger g | Apr 18, 2007 05:31am | #10
          When needed, I do that also.
          roger
            PaulBinCT | Apr 18, 2007 05:35am | #12
            Shhhhhhhhhhhhhhhh...whatdyacrazy?
            You're opening up "CanOWorms #113"
             PaulB
          2. roger g | Apr 18, 2007 05:40am | #13
            roger
            RichBeckman | Apr 18, 2007 06:03am | #14
            ROFLMAO!!!I opened up the General Discussion folder and saw thirteen replies and I thought "Oh sh!t!!! I must've been even stupider than I thought!!"I guess not.
            For the record...I never went into the attic...I was already replacing the fan...I'm not sure I have the cajones to wire it live, you should've seen me getting ready to trip it...VERY paranoid.
            Thanks to all.
            Rich BeckmanThis signature line intentionally left blank.
            Edited 4/17/2007 11:04 pm by RichBeckman
      2. DougU | Apr 18, 2007 05:31am | #11
        Bill
        I force trip all the time - whats the down side to doing it?
        Wouldnt force triping be equivilant to doing what the breaker was meant to do?
        I've never had any problem doing it but I'm just wondering how I could be doing anything wrong.
          BillHartmann | Apr 18, 2007 08:17pm | #18
          It is not that the force tripping is that bad (but it is not good for breaker life), but rather the relative safety, in this case, of the two options.With the forced tripping you have the hot and neutral exposed that you are trying to move one to the other and maybe a grounded metal box. And a mis-slip you can get between them.With the fan (and this depends on the what type of wiring that you have and if it is in a metal box, etc.But I would up cap the hot and separate the wires. Now this assumes that the wires separate easily. If not it is much more dangerous and would go wiwth tripping or delay the work.Then recap the hot so that you are clear.Then change out the neutral and ground connections. Then reconnect the hots using the wirenut to twist them together. Now if it is a case where the wires are stiff and not parallel to each other I would be less likely to do it hot..
        2. Mark | Apr 19, 2007 03:01am | #23
          I guess the one argument that I can come up with against "force-tripping" a breaker is,  what if the breaker is bad?
             I have on rare occasions run across an old breaker that for whatever reason no longer trips when overloaded.  The potential here is similar to the ol' "penny in the fuze"  situation of the olden days.    He indicated that the homeowner had left and that he no longer had access to the inside of the house and therefore the breaker box,  (At least that's what I think he was saying)    So by shorting those wires you might potentially cause a wire to overheat somewhere along that circuit and perhaps start a fire that you may or may not discover before you finish the job and vacate the premises.
          Ok, I know this is literally a one in a billion type of scenario,   but hey,  we're all aquainted with Murphy's law... " If I were a carpenter"
        3. Shacko | Apr 19, 2007 05:28pm | #47
          The down side is that breakers don't always trip, I've done it many times, but only when I can get to the breaker box. I also check with a meter to make sure the current is acually off. Luck........................................
          "If all else fails, read the directions"
    maddog3 | Apr 18, 2007 04:48am | #4
    let me get this right...you carefully unwired a hot circuit and then just shorted it out to kill the power !!!!!!!
    ..so you could do......what?
    BTW .that was kinda dumb....
    lucky for you the breaker tripped
    Heck | Apr 18, 2007 04:50am | #5
    Your first mistake was going in the attic. <g>
    _______________________________________________________________
    Once upon a midnight dreary, while I pondered weak and weary,
    Over many a quaint and curious volume of forgotten lore,
    While I nodded, nearly napping, suddenly there came a tapping,
    As of some one gently rapping, rapping at my chamber door.
  6. roger g | Apr 18, 2007 04:53am | #6
    When needed, I do it.
    roger
    1. brownbagg | Apr 18, 2007 05:01am | #7
      Field testing the breaker system, huhi do live in Alabama, so my advice might be worthless
  7. User avater
    Dinosaur | Apr 18, 2007 06:14am | #15
    How stupid is that?
    Wonder what happens if the wires weld themselves to each other because somebody screwed a penny behind the fuse....
    Seriously, Rich, you never know what's in the walls or the panel until you look. I'd rather work hot than take a chance on burning the joint down. But then, I bill by the hour....
    Dinosaur
    DON'T MISS THE FEST!
    foolish men call Justice....
  8. User avater
    JeffBuck | Apr 19, 2007 01:50am | #19
    I do that sometimes ...
    but usually I just work hot.
    Keeps ya on yer toes ... just pay attention and no one dies.
        Buck Construction
     Artistry In Carpentry
         Pittsburgh Pa
    1. dovetail97128 | Apr 19, 2007 07:35am | #44
      Least wise no who lives to talk about it. ;-)
  9. Junkman001 | Apr 19, 2007 02:24am | #21
    Do it all the time.
    Mike
    Insert initially amusing but ultimately annoying catch phrase here.
      RichBeckman | Apr 19, 2007 03:46am | #25
      Well, I appreciate the responses. Nice to know that I wasn't too wacko...A couple of points.I created the short by touching the hot to the neutral, not to the ground. At least one response above seems to assume I used the ground.Why that assumption? Would it have been better to short to the ground?? That doesn't make sense to me. The fan worked (the housing was damaged), so I knew the neutral was good.Dinosaur posts that the wires could've welded together. Was this really a possibility?? To be clear, when I shorted the wires, I did so by flicking one against the other (each held firmly, one in each hand) so they touched in only the slightest, briefest moment. Can they weld in such a moment?I wouldn't dream of holding the wires together waiting for the breaker to throw. If just flicking them like that didn't throw the breaker, I would've either done it live or waited for access to the box.
      1. DougU | Apr 19, 2007 04:00am | #29
        Very unlikely. Probably about the same as those odds that Sam posted regarding the breaker!
      2. DanH | Apr 19, 2007 09:22pm | #51
        On the few occasions where I've done this I've always been careful to "flick" the wires together, as you say, and been prepared to yank on the wire a bit if necessary should it weld.Another way to do it is with a screwdriver shaft (insulated handle) placed between the wires. This gives you more leverage to work with should a weld occur.Keep in mind that should a weld occur (and the breaker not trip) you have about a second to react before the entire circuit melts down. And, in about 0.3 seconds, the wire in your hand will be hot, with melted insulation.But I've never had the wires weld.
        1. brownbagg | Apr 19, 2007 10:26pm | #52
          Its best that when you short the wire, to scream in a high voice " oh, my god" then shake alot and fall back kicking.i do live in Alabama, so my advice might be worthless
          1. MVAgusta | Apr 19, 2007 10:39pm | #53
            The Roseland Ballroom in NYC used to keep a 2x4 next to the 400 amp stage disconnect, just to to knock a guy loose if he got zapped tying in live. Never worked there enough to see anyone get fried, but there musta been a reason for it.
  10. GHR | Apr 19, 2007 02:49am | #22
    If you work hot and get killed, your insurance may not pay.
    If you short the wires and get killed, your insurance may not pay.
    I would have waited for the customer to come back.
    1. 1muff2muff | Apr 19, 2007 06:11am | #42
      Will they replace the banjo you were holding in the other hand?
  11. RW | Apr 19, 2007 03:48am | #26
    Go to JLC and see what Joe sez :-)
    Real trucks dont have sparkplugs
    1. frost | Apr 19, 2007 04:00am | #28
      I'm on my way over to JLC tomorrow to watch for this.... could be great fun. Going out to the barn to find my hardhat just in case it gets real.  Kidding aside, it was a great post and really pertinent to some of us who (in rural areas) have to work outside of our trades. It explained a lot.  Stupid maybe, stupid question NOT!!
      BillHartmann | Apr 19, 2007 04:17am | #32
      Well Joe think that since Rich is not a licenesed electrican that he should go to jail.But if he was licensed and killed a kid they it would be OK.http://forums.jlconline.com/forums/showthread.php?t=32727.
        RichBeckman | Apr 19, 2007 04:28am | #34
        "Well Joe think that since Rich is not a licenesed electrican that he should go to jail."Well, yeah. Except there is no licensing of electricians in the state of Indiana and none in my locality.Plumbers got to be licensed, but not electricians.
          BillHartmann | Apr 19, 2007 04:33am | #36
          "Except there is no licensing of electricians in the state of Indiana and none in my locality."That is a minor detail to the faithfull over there.Read the thread.http://forums.jlconline.com/forums/showthread.php?t=32727And it got so bad that someone else started another poll.http://forums.jlconline.com/forums/showthread.php?t=36343.
          Gunner | Apr 19, 2007 04:34am | #37
             There must be some type of licensing.
             It's probably just not required in your area.
              Who dares, wins.
          http://thewoodwhisperer.com/
            maddog3 | Apr 19, 2007 05:17am | #41
            St. Joseph County ..which includes South Bend wants a license, but my county which is right next door doesn't require one Indiana is a hodgepodge of requirements with hardly any reciprocity that I know of.
            Gunner | Apr 19, 2007 10:21am | #45
                Kentucky used to be like that up until a few years ago. Now they want one state wide. And they want a licensed electrician to do everything. New circuits. Adding a receptacle. Everything. Unless your swapping out same for same you have to have a license.
                Who dares, wins.
            BillHartmann | Apr 19, 2007 03:25pm | #46
            GunnerLook at this thread.Starting on the 3rd page there is story about a 5 yo boy in Lousiville that was killed by metal garage door that was hot. It was caused by soem 14-2 used instead of 14-3 for a 2-way switch and the ground wire was used for one of the travelers.It was done by a licensed electrican/electrical contractor. But it appears that the actual work was done by a helper.http://forums.jlconline.com/forums/showthread.php?t=32727.
            Gunner | Apr 19, 2007 06:57pm | #48
               For some reason I think I've seen Brackney electric around. Before mandatory licensing came along we always bitched about jack legs doing faulty electric work.
               The complaint now is that all those jack legs got grand fathered in. So maybe in 20 years after they all get weeded out of the trade it might be a good thing but for now it really hasn't changed the quality. BUT! They can jerk your license and prevent you from ever doing electric work again.
              We have two guys in our shop that lied and got grand fathered in. I had to explain to one guy what a neutral was and how it worked. The other guy is a shade smarter. They don't do any electric work thank god. They got their licenses just in case it was ever needed.
                Who dares, wins.
  12. User avater
    Gunner | Apr 19, 2007 03:58am | #27
      You were stupid to tell everyone how stupid you were. I've got two words for you Federal Pacific.
      I googled this up for you real quick.
    http://www.inspect-ny.com/fpe/fpefire.htm
        Who dares, wins.
  13. Buttkickski | Apr 19, 2007 04:02am | #30
    I do it often, usually with my sawzall blade when I'm cutting into a wall...
  14. IdahoDon | Apr 19, 2007 04:43am | #38
    You've never worked on a client's house that had wiring all screwed up?  Give me a break.
    You had no way of knowing how well all the connections along the way are made up.  We've all seen wires simply twisted together and covered with cheap vinyl tape, perhaps in a box, perhaps not.  Even "perfectly fine" wiring that's back stabbed is just waiting for an excuse to quite working.
    If a sub, any sub, purposefully shorted a circuit, especially an old existing circuit, I'd ask them to take the day off to think about it.  If they don't see the error of their ways we can come up with a final check amount for the work they've done to date and call it water under the bridge.  Having seen an electrical fire in person caused by an arc I have no problem reducing my risk by eleminating the problem.
  15. seb | Apr 19, 2007 05:14am | #40
    Whoops!!! I thought I invented that!!..
    Only to justify my act, I think its ok..
    Bud
  16. hasbeen | Apr 19, 2007 06:13am | #43
    Evidently smarter than me. I would have hot wired it.
    "Doubt is not a pleasant condition, but certainty is absurd."
    ~ Voltaire
  17. RRav | Apr 19, 2007 08:25pm | #49
    I have a screw driver that I use frequently to do just that.
    Cross the circuit, and it blows.. leaves quite a gouge in the driver tho, so I only use it for that purpose
  18. DanH | Apr 19, 2007 09:07pm | #50
    I probably would have wired it hot, but only if I had confidence in the wiring. In older houses, where you may have a fusebox and/or old cloth/rubber wiring it's dangerous to do either. You never know when a fuse has been replaced with a penny or some of the wiring in the circuit is old lamp cord, so intentionally shorting the circuit can be dangerous. And wiring hot is risky with old wiring where the insulation may flake off without warning.
    Wiring hot isn't that difficult or dangerous, BTW, if the connections are made with wirenuts or easily-loosened screw terminals. You first disconnect the hot and tape it up, then disconnect the neutral and ground. Straighten the wires and wrap the end with more tape to protect the "hot" tape from getting pulled off, then withdraw the wire from the box. Reverse the procedure to reconnect.
    Of course, insulated screwdriver and pliers are a good idea ;) .
      RichBeckman | Apr 20, 2007 04:59am | #55
      Several posts have talked about older wiring and fuse boxes.The house in question is probably twenty years old or less. A nice houseI don't trust fuses much. And I've seen plenty of very suspicious wiring in many old homes in Marion. I really don't think I would have done it on an older home.
      Novy,They would have given me a key if I asked. I just failed to anticipate the need. Actually, I have a key now.
      Rich BeckmanThis signature line intentionally left blank.'
  19. Novy | Apr 19, 2007 10:42pm | #54
     Please don't take offense but personally I would never work for a customer that didn't trust me enough to give me a key and secondly I allways use a licensed electrician due to liability issues.
    On a hill by the harbour
Kimberley Robles, Decorative Concrete
In this interview, Kimberley talks about the importance of proper training, current concrete trends in the Bay Area, and the history of racist housing policy in San Francisco.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
  • Podcast 551: Members-only Aftershow—Badly-Built Homes
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
