In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
How to clean wood floor before refinish?
DonH | Posted in General Discussion on July 4, 2006 05:29am
I’ve torn out old wall to wall carpeting and uncovered an oak floor with shellac finish. I don’t want to lose the color created, I suppose, from the shellac and age, so don’t want to strip it. The floor has a texture or film on it from the padding which had sat on it for many years. What can I use to clean the floor prior to a few top coats of shellac? I’ve searched old threads here on related topics, and while most seem to say poly for floors, I’ll likely go with shellac anyway, knowing I may be touching up from time to time. Sorry to be bringing back a covered topic, but I didn’t find anything on cleaning or prepping the floor prior to shellac. Any advice? Thanks.
  1. Piffin | Jul 04, 2006 06:28pm | #1
    Minwax makes a wood Cleaner. There is a rinse solution to buy also after to clean the residue.
    but there is a good chance that things will end up mottled loking. That rug backing will be worse in areas of more foot trafic that back in the corner behind the table or whatever
    1. DonH | Jul 04, 2006 06:50pm | #2
      Thanks for the reply. I just checked the Minwax site and, unfortunately, they don't recommend their cleaners on shellac because of the possibility of wax. I'm assuming I shouldn't use something with much or any water. How about Murphy's oil soap? Is there actually oil of some kind in it? Maybe some solvent. Would mineral spirits eat the shellac?
      1. Piffin | Jul 04, 2006 07:42pm | #3
        Naptha is a cleaning agent.Try various thingsin small out of the way locations first.
        last year we did a lot of this over stained, oiled, and misused floors.
        Plaine old Turpentine on a rag with plenty elbow grease was the secret for most. But I don't know hjow that would work over shellac. To remove shellac, sometimes denatured alchohol works, but you don't want to remove it...
      2. BillBrennen | Jul 04, 2006 08:50pm | #6
        Don,Mineral spirits won't harm your shellac. Naptha, like Piffin mentioned, is just a "lighter" cognate of mineral spirits (shorter molecules, evaporates faster, less oily residue) so it also won't hurt the shellac. Detergents can damage shellac, ammonia will strip it off the wood, and alcohols will dissolve it. Acetone and lacquer thinner will also dissolve shellac. Plain water left on too long can diffuse into the shellac, leaving it cloudy.A quick wipe with a water-dampened rag followed by cleaning with naptha is a good idea. The water gets the gross soils, and the naptha will remove wax residues and greasy dirt. Bill
        1. DonH | Jul 05, 2006 02:43am | #8
          Thanks for the replys. Looks like I'll probably try the naptha or mineral spirits.
          1. Danno | Jul 05, 2006 02:52am | #9
            Incidentally, from what I remember, Murphy's is called "oil" soap because the soap in it comes from saponified oil instead of saponified fat, as in most soap. It is no more oil than the fat in soap is fat.
  2. TC | Jul 04, 2006 07:50pm | #4
    I just did the same thing on about 2000sf.of oak that had carpet on it for 20plus years used a product called crud cutter and a semi stiff bristle brush worked great
    BillHartmann | Jul 04, 2006 08:41pm | #5
    There was a resent thread on cleaning old woodwork.
    Waterless hand cleaner seemed to be a winner.
    Naptha is another.
    But you are really cleaning the residue from the foam so you will need to experiement to see what works.
  4. seb | Jul 04, 2006 10:19pm | #7
    Many times the pattern left by pad will actually be etched in the finish..Don't be surprised if you can't get rid of it without removing the old finish...(don't ask how I found that out LOL)
    Bud
Reusable Flood Bags for Fast Bulk-Water Control
These bags from Quick Dam arrive compact and swell to form a protective barrier on contact with water.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 486: PRO TALK With Builder and Remodeler Mason Lord of HVP in Kent, CT
  • Get Stunning Views With Folding Glass Doors
  • Keep Craft Alive Podcast: Episode 20, Ian Schwandt, TDS Custom Construction
  • Step-by-Step Install Prehung Exterior Doors
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
  • Outdoor Projects
    Buy Now
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
