How to patch & match old oak floor
2of12 | Posted in General Discussion on December 13, 2006 08:00am
Hi –
I’m new to this forum, but wanted to ask some pros a question about a current project. I’m renovating a 50 to 60 year old house. The floors are red oak, which I have to patch in several places. I was told that white oak would be a better match, since red oak fades after that many years. However, samples of the two still look quite different and stain differently. So, my questions:
1) is the guy right, that white oak will be better?
2) if not, should I use red oak?
3) in either case, will I have to correct the color by using different stain on the old vs. new?
4) any better ideas?
Thanks for your help. The whole project is slowly coming along, but this issue is beginning to be in the critical path.
2of12
  1. jet | Dec 13, 2006 08:09pm | #1
    I'm not the floor guy. Ditch is the floor guy.
    Having said that.....do you have any closets that you could take the floor out of to patch the middle of rooms and then replace the closet with either oak. It wouls show less that way.
    "No doubt exists that all women are crazy; it's only a question of degree." - W.C. Fields
  2. calvin | Dec 13, 2006 08:38pm | #2
    Jet's got it right, get the wood from the same job.  Color, size etc are pretty difficult to match with new stock.
    Here's a thread that goes through some of the process.
    Floor Patch
    Best of luck.
    http://www.quittintime.com/
    JDRHI | Dec 13, 2006 08:54pm | #3
    Any chance the original flooring is quartersawn?
    Happy
    Holidays
  4. ditch | Dec 13, 2006 09:05pm | #4
    50 to 60 yrs. isn't that old. Red Oak and White Oak don't match.
    I imagine that you are patching returns or water/pet damage. In any event buy a bundle or 2 of RED OAK, Tooth the new boards in matching the grain patterns as best as possible. Resand and refinish the floors. Done.
    If you don't want to refinish the floors, don't expect the patches to match.
    1. 2of12 | Dec 13, 2006 10:10pm | #5
      Thanks for all your suggestions. I had thought it would be too difficult to get it out of the closets without damage. So, I'll study the Quitin' Time suggestions. I do plan to refinish the floors: they're mostly in pretty good shape. We took out part of a stone floor in the entry and removed a closet, to make the dining room larger. We also removed a couple of walls. Most of the replacements will be lenghwise, but a short section is across the direction of the planks. Also, there are a few dog stains. I bleached out one, then neutralized with vinegar, but don't know if that will affect final color. It's seems easier to bleach than to replace: any problem with this if the stain isn't too deep to bleach? I can get new red oak in the correct size: 3/4" by 2 1/4W wide, rather than pull it out of the closet. Would this be a good match, or should I take it from the closets?Thanks again for all your help!
      2of12
      1. ditch | Dec 13, 2006 10:23pm | #6
        .75 X 2.25 is readily available and will match up fine. We have cannabalized flooring from closets in the past, but only when finding a suitable replacement proved difficult.
        One technique I began using on pet stains was to hand paint faux grain over the stain. Acryrlic paints in various wood tones works well using an artists brush. Faux paint over the stain between the first and second coats of finish.
PVC for a Rot-Proof Fence
Built with rot-proof material with traditional tools and techniques, this classic border is engineered to never sag.
  • Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
  • Podcast 551: Members-only Aftershow—Badly-Built Homes
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
