I just replaced the faucet in our bathroom, and the footprint of the new one was less than the old one. There was some discoloration under where the old faucet had been, so I sanded it down. I now have an area which is scuffed up by the sanding. Is there a chemical I can apply which will “melt” the Corian back to a smooth surface? I’ve tried paint thinner so far, to no avail. What should I be using (other than a blowtorch)?
* for more information.
You smooth out Corian just as you would a wood finish, by using progressively finer abrasives on it, finishing with a polishing compound. If you're truly stumped, call your local Corian or Avonite dealer/installer for help. Also go to
*DON'T use a blowtorch. Corion is not very tolerant of rapid heating and cooling; you could get stress fractures all over the place. Sand up to 320 or 600x, switch to Scotchbrite pads, maroon then grey until you match the surrounding sheen.
*Don't worry, I was only kidding about the blowtorch. Thanks for the advice, though.
