A few simple but important questions… Which is the best heat recovery ventilation unit for a reasonable price? Does flexible duct work significantly decrease efficiency as opposed to sheey metal ducts? In a house with a small swimming pool(endless pool) is a seperate hrv neccessary? I’m told it is but the cost of two seperate hrv units seems high.
From plumbing failures to environmental near disasters, OHJ staffers dish on our worst and best moments.
If you keep a cover on your pool when not in use, you shouldn't have a problem. Most of the heat into a pool goes to evaporating water. Minimize it.
I used flex duct for our 20k cu ft, .5 ACH system. Will again. You move so little air, it's no problem. I also ran lines to our closets.
What's the design? How many cu ft? What ACH? I don't know commercial systems as I built my own. Very efficient. It's very similar to a Lossnay. Strong recommendation to unbalance the fans such that all leaks go out.
