In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
hvac vacuum pump
1110d | Posted in Energy, Heating & Insulation on April 15, 2004 11:45am
A typical hvac evacuation vacuum pump…how many inches of mercury will these pull?  I need a vacuum pump which will move around 6cfm and pull 24″ of vacuum (not concurrently).  It’s looks like the hvac ones will work, but the mfr’s don’t list the amount of vacuum their units can generate.
Don’t suppose anybody has a used one they want to part with…
    IMERC | Apr 16, 2004 12:04am | #1
    If you have need these folks have the solution and the pump.
    Most excellent folks....
    http://www.eco-web.com/cgi-local/sfc?a=/index/index.html&b=/register/05783.html
    Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming....
                                            WOW!!!   What a Ride!
  2. SteveL | Apr 16, 2004 01:32am | #2
    HVAC systems should have a vacuum of approx. 500 microns (about 29.7 in Hg) before charging with refrigerant. What is your application? Ebay has many for sale but a new 7.5 cfm pump will run about $400.
    1. brownbagg | Apr 16, 2004 03:01am | #3
      I have a couple hvac pumps. but when I first started I would use a old refrigerator compressor till it burn up. work good.
    2. 1110d | Apr 16, 2004 06:08am | #4
      This is for some figerglass work.  You apply vacuum to the layup to suck all the air out of the resin.  I was looking at the units on ebay (much cheaper than new) but most were not listing the vacuum level.  I even went to the mfr. sites and they wern't listing it there either.  It looks like I have the pump type picked out, now I just have to find one for the right price.  Thanks for the help guys!
  3. junkhound | Apr 16, 2004 06:12am | #5
    At just 24" Hg needed, an air compressor will work, but you will have to fab something over the intakes for the pickup. The 6cfm you quote is way too much for typical hvac, which are up to 2 cfm but need to pull less than 50 microns (29.9+ Hg when barometer is 30). An old chrysler dual cylinder air conditioner compressor wioul work nicely.
     Where are you located (too many here do not put anything in their member profile) , if in Pacific NW (Renton WA) come by when nearby and I'm sure I've got something in one of the back sheds that will work for you free.
    If  memory is still good, Vacuum pulled capability for air compressors is very roughly 30"Hg - 30*(1/compression ratio), so if a compressor can put out 147 psi, it will be able to pull close to 27" Hg.  There's a couple other factors in that equation, but too lazy to look up the exact formula tonight, but a typical air compressor is over 24" Hg anyway.
    1. CorvairDuVal | Apr 16, 2004 06:27am | #6
      I still use an old refrigerator compressor to evacuate HVAC systems.
      Maybe you could raid several old refrigerators and parallel the compressors to get more cfm capacity? Old refrigerator compressors should easily pull 24 inches of mercury in vacuum. Do add refrigerant oil occasionally to the suction side of the compressor to lube it.
      Frank DuVal
    2. 1110d | Apr 16, 2004 04:29pm | #7
      I actually live in the midwest, so I don't think I'll be stopping by any day soo! lol
      With a refrigerator compressor, is it as easy as it seems?  You just pull the unit out, wire it up and then add a oiler?  The motor and compressor is one unit right?
      1. junkhound | Apr 17, 2004 07:03am | #8
        as easy as it seems
        Yeah, it is, all you gotta do is add a switch in place of the thermostat and solder on a fitting to the typical 1/4" tubing.  For your application, you likely have big leaks tp the F/G cover, which is why you need 6 cfm, you are gonna need like 10 or more old fridges for that - I don't even have that many <G>
Industry-First Cordless Rebar Cutter and Bender
A brushless motor and 36v batteries power Metabo HPT’s cordless rebar bender and cutter.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Keep Craft Alive Podcast: Episode 20, Ian Schwandt, TDS Custom Construction
  • Installing Prehung Exterior Doors
  • Podcast 485: Air-Sealing a Mobile Home, Owner/Builder Tests, and Ready-to-Tile Shower Bases
  • Podcast 485: Members-only Aftershow
BOOKS, DVDs, & MERCH
Shop the Store
  • Outdoor Projects
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
