I-joists for weenies
| Posted in Construction Techniques on December 5, 2002 12:02pm
My floor structure, planned, has bearing walls and beams creating spans whereby I could frame with 2×8 joists, but I prefer I-joists to sawn lumber.  Does anyone make a 7-1/2″ I-joist?
  1. IronHelix | Dec 05, 2002 05:17am | #1
    This would mean that your max joist length would be about 12 ft span....correct?
    And I do not remember ever seeing any I-Joist listing smaller than 9"(+/_) listed in any manufacturer's spec sheets.
    ....................Iron Helix
  2. heck22 | Dec 05, 2002 05:22am | #2
    Maybe you can find something useful here:
     http://www.beconstructive.com/professionals/21st_ijoists.asp
    I have never seen any under 9.5" tall.
    jw
    what the heck
    was I thinking?
  3. Ragnar17 | Dec 05, 2002 05:56am | #3
    Gene,
    So what's the problem with going with a slightly deeper I-joist?  Are you trying to match existing conditions?
    By the way, I saw a drawing you posted regarding a truss design.  What program was used to create the drawing?
    Ragnar
    Edited 12/4/2002 10:10:51 PM ET by ragnar
    1. Boxduh | Dec 05, 2002 03:35pm | #4
      I use Cadkey 97, a fully-functional 3D mechanical design package.  Pretty much the same features as AutoCad.  If I was going to do residential design work regularly, I would buy one of the newer pieces of software.  Chief Architect comes to mind.  Here is a rendering of a version of my deckframe, sitting atop main floor structural and walls.  Disregard the second copy, as I mistakenly loaded the file twice.  Regarding the I-joist issue, I think I will redesign using light-duty 9-1/2" I-joists spaced at 19.2".
        BossHog | Dec 05, 2002 03:43pm | #5
        Nice picture. Don't forget to layout your plumbing drops.............(-:
        I think there were initially 7.5" I'joists and beams out there. But they never caught on - Not enough demand. So I don't think you're likely to find any now.
        BTW - On your drawing, it looks like you've got some awfully long cantilevers at the corners of the building. Make sure you check out the I-joist specs if you're doing cantilevers.Q: How many Microsoft phone help technicians does it take to change a light bulb?A: Please hold, your call is important to us.
        1. Framer | Dec 05, 2002 07:06pm | #6
          Boss,
          Your right about the 7-1/2" I J's, I used them about 8 years ago for a garage ceiling on a house that I framed.
          I haven't seen them since.
          Boss as I'm typing to you right now the lumber yard just called me, he's saying a company called Jager Industries might have them. I'll try this website.
          Joe Carola
          http://www.jagerindustries.com
            BillHartmann | Dec 05, 2002 07:14pm | #7
            The website is jagerind, but that just redirects you to;
            http://www.jager.ca/
            CORRECTION that leads to their home building division.
            Here is the link to their engineered wood products.
            http://www.jagerbuildingsystems.com/home.html
            Edited 12/5/2002 11:19:18 AM ET by Bill Hartmann
          2. Framer | Dec 05, 2002 07:17pm | #8
            Boss and Bill,
            I just talked to the lumber yard, the correct websites is:
          3. nascorpa | Dec 05, 2002 07:32pm | #9
            Gene,
            You may want to call Nascor in Calgary. They manufactur a 5 1/2" and 7 1/2" I-joist that is incorporated into their all panels. Not sure if they would just well you the I-joist. (800)792-9555 or (403) 243-8919.
            John
        2. andybuildz | Dec 05, 2002 07:50pm | #10
          Bossman
                 the only serious cantilever seems to be in the front left corner where it looks like he has a footing for a post?
          aIt's not who's right, it's who's left ~ http://CLIFFORDRENOVATIONS.COM
          1. Boxduh | Dec 05, 2002 09:58pm | #11
            Those front two corners have columns under them.  16 x 16 stone ones, sitting atop piers.  The flush beams shown at the far end are bearing walls, and it is one of the places where I could use full length 27 footers, if I can find a 7-1/2" I joist.
      2. Ragnar17 | Dec 05, 2002 10:45pm | #12
        Thanks for the reply, Gene.  Drawings look great as usual.
        Ragnar
A New Approach to Foundations
