i need help refinishing my wood floor
pierreg | Posted in General Discussion on September 30, 2005 02:57am
Hi everyone,this is my first time here ,i just suscribed to fine home building but i have a question.I have a 200 sq ft oak floor that has been sanded.I am gonna put a sanding sealer on it and then a a few coats of varnish.My question is how many coats should i put and should i be sanding between the coats and what should i be sanding with ,screen or paper.
thanks for the help.
  1. TRIGGER | Sep 30, 2005 03:35am | #1
    Varnish? Do they still make that stuff?
    1. pierreg | Oct 01, 2005 05:50pm | #7
      if you can't be helpfull don't waste your time.
      1. TRIGGER | Oct 01, 2005 10:50pm | #14
        Dear Sir,
             One thing that might be helpful to you, in the future, is to also try the Knots forum. They can be helpful as well as this group of seasoned craftsmen, with certain questions you may have. It's based on the Fine Woodworking magazine.
        TRIGGER
        I hope that made sense.
        Edited 10/1/2005 3:53 pm ET by TRIGGER
        1. pierreg | Oct 03, 2005 05:11pm | #15
          makes a lot of sense ,you're all very helpfull thanks a lot i'll let you know how it turns out.
  2. Piffin | Sep 30, 2005 04:24am | #2
    Why the sanding sealer? WE only use that for a way to seal a floor agianst mositure and stians - a thin wear coat while we are working over the floor until it can get a real sanding and finish. We also use it sometimes for door parts before assenbling.
    If by "varnish" you mean the commonly used polyurethene, you should know that most polys are not compatable with sanding sealer.
    make sure you are clear on what product you want to use and then we can go to town on it.
    1. FastEddie | Sep 30, 2005 04:35am | #3
      Sanding sealer can also be used to help get an even stain coat, but that's probably not an issue here unless he has cherry floors.
  3. maverick | Sep 30, 2005 04:53am | #4
    Stay away from sanding sealer. Its not a durable undercoat. from my experience it can be a little waxy.
    I got into an argument with a pro painter about this very issue. I contend sanding sealer is a fast and cheap method to get to to finish coat all the while compromising quality
    You need to apply 3 coats of polyuerethane and you only need to sand before the final coat
  4. ponytl | Sep 30, 2005 05:33am | #5
     3 coats of poly...  i use a regular comerical floor buffer with a scotch bright type pad between coats... the white pad is pretty fine... use it then a tac cloth  to remove all dust... then recoat...
    p
    SteveInCleveland | Sep 30, 2005 05:41am | #6
    Check into a Benjamin Moore product called "stays clear".  It's all I ever use on wood flooring.  They have high gloss and low lustre.  I prefer the look of low lustre.   Since it is a water-based product, you can put both coats on in a single day.  Also, no strong odors.
    http://www.benjaminmoore.com/wrapper_pg3.asp?L=prod&K=intprods&groupid=25&productid=95#article
    from the webpage.....
    View ImageBenwood Finishes¯ Stays Clear¯ Acrylic Polyurethane Low Lustre 423
    View Image A premium quality product that combines the attributes of polyurethane and acrylic to produce a clear, durable, non-yellowing finish. Finished surface provides high resistance to abrasion and protection against alcohol, water, and most household chemicals and stains.
    Features
    View Image  Does not yellow like varnishes.
    View Image  Tintable to many decorative shades.
    View Image  Soap and water clean up.
    Color Available
    Clear*
    View Image  Use: Interior
    View Image  Gloss: Low Lustre
    View Image  Type: Acrylic/Polyurethane
    View Image  Clean Up: Water
    View Image *May be tinted with up to 2.0 fl. oz. Benjamin Moore¯ Color Preview¯ colorants per gallon.
    The Breaktimer formerly known as "Steve-O"
    "Preach the Gospel at all times; if necessary, use words."  - St. Francis of Assisi
    1. pierreg | Oct 01, 2005 05:51pm | #8
      thank a lot steve i will try it next week ill let you know how it turns out.
      Would you sand between coats and what would you use?
      1. Piffin | Oct 01, 2005 06:10pm | #9
        There is no need to be rude. Do you always go around insulting those who are trying to help you?
        Tigger and I were both trying to get you to clarify the actual product you wanted to use, because the advice you need is specific to the product.Now, it appears that you do not want Varnish, but a water borne polyurethene instead?I sand lightly with 120 between first and second coats and sand with 150 between second and third coats, always with the grain.
        1. TRIGGER | Oct 01, 2005 10:36pm | #13
          Thank you,
                      respectfully to all of you, tRigger
        SteveInCleveland | Oct 01, 2005 06:52pm | #10
        Since it is a water-based product, a very light sanding may be required if the grain feels slightly raised.
        Be sure to use a short nap mohair roller cover to apply it.
        Let us know how it turns out for you.
        1. mrfixitusa | Oct 01, 2005 08:23pm | #11
          A friend told me he heats polyurethane prior to applying it to the floor.
          He takes a mop bucket and fills it half way with boiling hot water.
          He then places heavy plastic as a "liner" in the bucket and he pours the poly urethane in and it gets heated this way.
          He says he was taught to apply floor finish this was in the military.
          I have never tried this.  Again, this is just something I was told.
          1. Piffin | Oct 01, 2005 10:15pm | #12
            Maybe, maybe not.The warmth would lower the viscosity and possibly let it penetrate certain woods faster when using oil based, but it would also cause the volatile oils to flash off quicker and give an irregular surface finish, even possibly creating some cold laps.Since the wood of the floor itself would still be normal temp, and cool the finish oil off quickly, I doubt that there would be much advatage
