In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
I WANT A RUMFORD FIREPLACE
cutawooda | Posted in General Discussion on December 25, 2002 12:15pm
I am in the process of building my own house. Nothing has happened yet but the plans being delivered and getting bids. Among the many “white-outs” that I made on the blue prints were bumping out the family room 5 more feet so that I could have nice rumford fireplace in the large family room. The original plans had a small bump-out for a prefabbed fireplace with a direct vent out the wall. The bump-out was toward the exterior. This room is a nice large one and DEMANDS a “statement” fireplace.  The problem now is that I am not sure how the rimford will sit in there. It is a slab foundation. Does it need to be flush with the inside wall or set outside the exterior wall. Should the concrete guys recess the concrete about 4 inches to alow brick to flush out with the slab. Do most masons know how this will work. Do most masons know how to builsd a rumford. I guess I need to get with a mason huh? thanks
  1. Piffin | Dec 25, 2002 12:25am | #1
    Yes, you need to speak with masons in your area but you can fit a Rumsford into nearly the same depth as a metal prefab because one of the features of the Rumsford is that it is shalow. It is the heaight that differs and the angles of the back walls.
    Slab on grade will have a thickend edge anyway. That thickness should extend to lie entirely under the masonry mass with rebar passing through @ 12" OC.
    If it is a two story or higher, the added mass might mean that you need a separate footer.
    "The first rule is to keep an untroubled spirit.
    The second is to look things in the face and know them for what they are."
    --Marcus Aurelius
    1. Haole27 | Dec 30, 2002 01:26am | #9
      wow, piffin does reply to Every post! thank God we have someone who truly "knows it all!" and it was within 15 minutes of the first post too! Everybody raised their glass and chug!
      is there any subject he has not mastered?
      1. MarkH128 | Dec 30, 2002 02:25am | #10
        Stalking?
  2. notagain | Dec 25, 2002 01:59am | #2
    How 'bout one of these? How far from Connecticut are you?
        Rod
    1. Piffin | Dec 25, 2002 06:37am | #3
      Schmidt has the proportions of a real Rumsford, more so than any of the others, it looks like. Lassow is the one I like best for period apperance and style.
      Great Works All!.
      --Marcus Aurelius
      1. notagain | Dec 25, 2002 03:14pm | #4
        Thanks Piffin,
        I appreciate the comments. I also worked on the mahogany surround of Lassows. Spent almost 2 years on that job, from the brick foundation, 4 fireplaces, oak timber frame kitchen, wainscoting, and everything in between. I'm quite proud of that job.
        Here's a picture of Schmidts, also a period job. The timber frame was taken down, and relocated. Six fireplaces in this one. (5 in main house, 1 in addition).
        Piffin, if I read these posts correctly, you're from up Maine area. (I know, Down East, but up from Connecticut).  I was born in Lincoln, Maine. Been in Connecticut most of my life, but I'm still a Mainer, they can't take that away from me. Always thought about heading back up.
        Rod
  3. MikeR | Dec 26, 2002 03:56pm | #5
    I built my own in my house just a year ago.   Got all my info from Superior Clay's website (dimensions, etc) Bought all the materials from them as well such as throat curves and liners.  Works great!
    Get Count Rumford's book as well as its vital for understanding the design.
    Make sure you local code accepts the design as well as they are more shallow than a standard design.
    Mike
    rjw | Dec 27, 2002 12:53am | #6
    Be aware that fireplace dynamics can be significantly affected by how tight the building envelope is, and there is a reason for the move away from open fireplaces!
    Be sure that the fireplace design/function will work with the envelope specs
    _______________________
    "I may have said the same thing before... But my explanation, I am sure, will always be different."  Oscar Wilde
  5. wrick2003 | Dec 27, 2002 02:04am | #7
    my friend, you are in luck. find the following book:
    "the forgotten art of building a good fireplace"
    by vrest orton
    yankee books publishing box c3fp  depot square peterborough nh 03458
    my old copy was preweb so no web address.     good luck.
  6. MarkH128 | Dec 27, 2002 03:37am | #8
    FYI
    This is a list of masons in that claim to build rumford fireplaces.
    http://bricknet.com/mason.html
Cutting Small Tile
Cutting small tiles comes with extra challenges. Learn how a simple addition to your saw's sliding table can make cutting small tile easier.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 463: The Best of the Fine Homebuilding Podcast, Volume 3
  • Fine Homebuilding – July 2022, Issue #308
  • Pretty Good House Book Excerpt: Copper Farmhouse
  • Fine Homebuilding Issue #308 Online Highlights
Justin Fink Deck Building Course announcement
Sign Up See all newsletters
BOOKS, DVDs, & MERCH
Shop the Store
  • Outdoor Projects
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Shop the Store
  • Issue 308 - July 2022
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • Issue 304 - Dec 2021/Jan 2022
    • Why You Need Blower-Door Testing
    • Passive-House Standards for Everyone
    • Window Replacement With a Side of Rot Repair
  • twitter
Sign Up
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
