While I’m here I should also ask; Why can I not find any “R” values for Icynene foam insulation?
They seem quite adept at side-stepping an answer to that. Or- maybe I just can’t find it.
Also, if you have a roof leak, would you be able to tell before the roof sheathing rotted?
TIA
Here is more info on the stuff than you would have thought to ask.
You should check these folks out as well.
Thank you!
I just noticed further on that I'm not the first to ask these questions.
Corbond sounds the business but I certainly hope it's less expensive than I was quoted for Icynene! And I'm far enough along so that pay back period means nothing.
Edited 2/14/2004 2:39:01 PM ET by Len
>> Why can I not find any "R" values for Icynene foam insulation?
My guess would be because the R value varies with the installed density, and real consistent density is not easy.
But hey, as some famous guy said, whaddu I know.
