Infloor heating hardware costs.
Rosey | Posted in Energy, Heating & Insulation on April 18, 2007 01:43am
I am putting in an infloor Wirsbo 1/2in hepex plus system with 17  300 ft loops.
What is a ballpark estimate of costs for the pumps, fittlings, and other hardware
to run these 17 loops?
Thanks.
  1. jayzog | Apr 18, 2007 05:00am | #1
    You got about 3K in tubing. The rest depends on what your doing... Staple up,plates,high mass, how your zoning,controlling, etc. lotsa details needed.
    You must have a design,because you know it is 17 loops, go to pexsupply.com & price the parts.
    If you don't have a design, well thats where you should start.
    1. Rosey | Apr 18, 2007 07:43am | #2
      There must be a general formula for a range of cost for 17 loops for the motors, valves, etc.  I am not interested in boiler cost on this.  I'm just trying to get an idea. The pex cost is about $3500 (hepex plus).
      eg, would an estimate be 1-3,000?   or more?
      1. rich1 | Apr 18, 2007 08:16am | #3
        No formula.  You need to know the design, figure out parts needed and then get local pricing.
      2. MikeHennessy | Apr 18, 2007 04:05pm | #4
        Way too many variables. How many zones/thermostats? (Not necessarily the same as the number of loops.) Are you using a seperate pump for each zone, or using controllers to share pumps over more than one zone? What type of pump - iron or bronze? Don't forget the valves, expansion tank, backflow preventer, air eliminator, manifolds and 1-1/4" (or larger) copper piping and fittings to hook everything into the boiler -- they'll cost as much as the pumps, etc. How are you running your piping -- underfloor with/without fins or in quick-trak? You can't even get a rough guess until you have a design that specs all this out. I'm not even sure how you can know how much/what size pex you really need until you've had a heat loss calc and design done. Your supplier should be able to put this all together for you.
        Mike HennessyPittsburgh, PA
  2. cameraman | Apr 18, 2007 04:07pm | #5
    You need a heat loss and a design! I am going threw the same thing now, start with a heat loss then design the system to meet the needs.
    Pushing 1/2" to 300' loops is a bit much, 250' max. loops is more like it.
    You will be much happier with the end results with the proper planning.
Behind the Scenes of a Concrete Batch Plant
The batch plant is your partner in getting high-quality concrete on your job site.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
