We are in the process of remodeling our home and will be adding exterior foam then doing a rainscreen siding install. Because I’m comfortable with either of the so called innie and outie positions of installed windows, our decision will be heavily based on the finished exterior appearance. And, like so many others, my wife has difficulty in visualizing from construction detail drawings. So… can anyone post or direct me to some photographs on the web that depict the difference?
Thanks so much.
bump
Innie/Outie pictures
Check out this slides deck:
http://www.buildingscienceconsulting.com/presentations/documents/2010-10-06_DER_Case_Studies.pdf
Thank you.
