HOW TO INSTALL A GRANITE COUNTERTOP
I want to install a granite countertop. The current countertop is ceramic tile. Do I have to remove the tile first?
Recommendations on what adhesive to use? and what sort of grout/caulk to use between granite slabs?
I would ask whomever you are buying the slabs from to give you their advice.
It will be easy[g].
Is this a joke?
Do you want to install a countertop yourself or turn to a contractor?
Epoxy is the adhesive you want to go with.
You need to use Epoxy for the job, this is the right adhesive.
Epoxy hands down, if you can't do it, hire a contractor.
