I wish to install my own boiler and the two oil tanks. It seems fairly straight forward. What I need is a picture book with simple instructions. No permit is needed as verified by the oil company because this is my own place. They are willing to take over if I get stuck. Any suggestions on web sites or books is appreciated.
*From a quick perusal, it appears that there is not a wealth of information on the Web about installing fuel tanks. About the only one I found was:http://www.medfordfuel.com/monitor_tank.htmdifferent search terms might give you some more.A discussion of above ground vs underground tanks is included at:http://www.heatingoiltanks.com/And there is a site that discusses the problems with leaking tanks http://www.epa.gov/swerust1/1998/index.htm
*I don't know of any good sources, and I wish that I had. I installed my own, a Veissmann, and it was the most intimidating part of building our house. However, the boiler came with good instructions and the supplier answered questions when I got stuck. Early on, I gave up on comprehending the entire system, and focused on the task at hand. Because the supplier and manufacturer had really done the thinking for me, this approach worked. Now, I understand the whole thing and that gives me the advantage of knowing how to fix most glitches that might pop up. Take a look at the paperwork that comes with the boiler. Be sure to install the correct pressure-relief valves so you don't blow up the house. That and some plumbing experience ought to see you through. Ask questions and persevere.Andy
*Almost forgot to mention, during the one cold snap we had in Portland last year, the oil supply to the furnace in the house I was renting froze solid. Not the best time to be without heat... This might be because they never expect it to freeze here and don't normally add dispersants to purge the water that collects in the tank. Anyway, you might want to insulate your line or provide some means for thawing the bottom of the tank and critical points in the line. Others in colder areas should know much more about this than I do.
