I’m installing a new steel roof over trusses and purlins on a 4/12 pitch, is the customer asking for trouble with skylights?? This is standard steel not standing seam. Are there special dam and flashing kits available??? thanks
stan
stan
Stan
The key to the flashing kits, if available, will be installing the skylight on a raised curb. Velux are the only manufacturer that I know of that make a special flashing kit to go with their
i flush mount
skylights for steel roofs. Even so, on a 4/12 (which is shallow for steel roofs) you would be better off retrofitting a standard skylight to fit onto a raised curb, then you can use stock steel roof
i side wall and end wall
flashings to fabricate a good seal.
-pm
*My choice in this shallow a steel roof would be to not install a skylight. It is really tough to do a quality, leakproof job. But, if you must, Patrick's advise is right on I think.
*If you can, locate the skylight so that the top flashing is under the ridge flashing. That way you avoid one whole set of problems.
I'm installing a new steel roof over trusses and purlins on a 4/12 pitch, is the customer asking for trouble with skylights?? This is standard steel not standing seam. Are there special dam and flashing kits available??? thanks
stan
