Is there any insulation rated for direct contact with 4″ b-vent?
How do you seal the penetrations wher b-vent comes through the rim joist?
Any input would be helpful.
Dave
Dave
Framing the floor inside a crawlspace foundation keeps a gable-end addition close to grade.
We used to use asbestos.
metal flashing makes the seal. cut the flamable an inch away
That's as good as it gets, huh?
Thanks,
Dave
There are silicones rated as high as 2000°F and firestop caulk products, but you won't span an inch with silicone.You can just make the metal flashing sealed tighter.
