insulating an old house
Shirlita | Posted in General Discussion on February 14, 2007 09:21am
We are replacing the siding on our circa 1875 balloon framed house in west Quebec,Canada. There is currently no insulation in the 2×6 walls. What I was thinking of doing is installing foil backed ISO panels (Energy Shield) underneath the new Canexel siding. The carpenter helping me with the Renovation thinks that any sort of impermeable or semipermeable rigid insulation on the outside of the house is a bad idea since it would trap any indoor moisture in the wall. He suggest opening up the wall and insulating the cavities from the outside, house wrap and then siding. I like the idea of rigid foam insulation on the exterior because there is no thermal bridging and missed un-insulated areas. Winters here by the way are long and cold. Any advice would be much appreciated.
  1. MikeSmith | Feb 14, 2007 09:52pm | #1
    2x6 walls ?
    i'd  blow the walls from the outside with cellulose, using a two or three hole blow
    1. Piffin | Feb 14, 2007 11:36pm | #2
      And in this case I agree.Wonder how close he is to Dino? You could make it a working vacation!;)
    2. mclaren | Feb 15, 2007 02:28pm | #5
      Mike,
      I've read your replies and comments for a long time and
      appreciate your opinons and knowledge.
      That said, why choose cellulous over foam? I thought the
      wood fiber would hold moisture and lead to decay?...
      that's the arguement I've heard for foam.
      Mclaren
      1. MikeSmith | Feb 15, 2007 02:39pm | #6
        well, 1st, it's  a 2x6... so you lot's of depth
        2d, if you put foam on , where will you put it .. on top of the sheathing , right ?
         so ,what will you put in the wall cavity ?
        if you are going to inject foam, then you will have to open each stud bay so they have access, they won't injuect it into the closed stud bays , or will they ?
        so.. if all of the above is true.. then i'd take the cells in the stud bays over the foam sheets on top of the sheathing..... you'd  STILL have to fill the stud bays with something .. what ? fiberglass ?... don't waste your money
        nope ... this would be a no-brainer to meMike Smith Rhode Island : Design / Build / Repair / Restore
        1. mclaren | Feb 17, 2007 05:34am | #7
          fair 'nuff.
          I've just "heard" about cellulose holding moisture and causing rot.
          Vs. foam as a vapor barrier, which causes it's own problems...
          'preciate your input.
          Mclaren
  2. precision | Feb 15, 2007 03:52am | #3
    Nice to see a fellow canuck out here I am from new brunswick ( Y fait tu frette assez pour toi)
    I would blow-in the wall cavities with cellulose from the outside by making holes with
    a hole saw at the bottom, and every 48"or so, and top, and plug the holes as you go up the more holes the better because there could be all kinds of obstructions in there.
    and as for rigid insulation a good cladmate on the outside would be advisable in order to eliminate any thermal bridges at the studs 1" minimum 1 1/2" preferable since you don't know if some spots will be entirely filled in. the cladmate or any Type 3 or 4 rigid insulation will let moisture trough unlike the Type 1&2 insulation like Dow's styrofoam SM.  And under that Canexel make sure you put a strapping to create a air space so that the back side breaths.  If you read the installation brochure you will see that if you don't do this they will not honour their warrantie.
    Stay away from that foil faced rigid insulation unless you put it on the inside of your house which wouldn't be economical in your case. that stuff was designed for the lower united states where they are trying to keep the heat out of their houses we are the opposite here we try to keep it in.   Aluminum is an excellent vapour barrier and the vapour barrier in our cold climates is always on the inside so if you use that on the exterior of your walls you will rot your house.
    I also suggest that you consult an insulation specialist I know there is allot of those going around quebec they usually have these big trucks with all their sprayed urethane insulation equipment and cellulose blanket walls systems and all that good stuff,  general contractors usually sub out to them. these guys take all kinds of energy efficiency courses and know how to do R-2000 homes so they are full of knowledge in this subject and insulating old houses is their specialty.
    1. dude | Feb 15, 2007 11:20am | #4
      we tore open a old farm house near wakefield years ago and prior to starting owner told us to save the blown in insulation in the walls
      out of the four walls we got about 2 bushel baskets of  insulation . & he couldent believe it
      the hpuse was ballon framed and you could drop a rock from the attic to the basement except at the windows so iguess he was taken for a ride
    2. Shirlita | Feb 28, 2007 07:32pm | #8
      Thanks for the replies and sorry for the delay in responding ! I like the blow-in cellulose idea. As for the cladmate, I had a insulation contractor come and give me an estimate and he suggested that after the blowing of cellulose, to address thermal bridging, gaps in cellulose and, to act as a wind break that we spray the exterior of the house in a Polyurethane foam (Heatlok). Looks like pretty impressive stuff. It's made from recycled plastics and soya and is a zero ozone depletion substance.According to the contractor, any applied thickness under 1 1/2 inches does NOT act as a vapor barrier. Says it's expensive though. Have yet to receive estimate so I still don't know how expensive. Does anyone have any experience with this stuff ? Are there any alternatives out there ? How about Precision's idea of installing Cladmate ? Also, in response to Mike's post. What do you mean by 2 or 3 hole blow ? Is that 2 or 3 holes per bay ?Thanks again everyone !
      1. MikeSmith | Feb 28, 2007 07:39pm | #9
        i'd start with a two -hole blow.. one about 16" from the top of the bay  & one about 16" from the bottom of the bay
        AFTER i blew the first bay . i'd bore a hole in the middle of the bay and see what kind of compaction i was getting.. good compaction, i'd stick with the 2-hole
        if the compaction was so-so, i'd switch to the 3-holeMike Smith Rhode Island : Design / Build / Repair / Restore
        1. Shirlita | Feb 28, 2007 07:42pm | #10
          Right. Got it. Thanks !!
          1. karp | Feb 28, 2007 09:42pm | #11
            What about a vapour barrior? Does the celluose act as one? The importance of a V.B. has been drilled into me for years and having removed enough moldy f.g. batts over the years, I do tend to pay attention to it on my projects. My summer place is in southern Que. and I have half of the house insulated because I've been doing 1 room at a time, strip the drywall off the inside and go from there. Is there a better way?
    3. DanH | Mar 01, 2007 01:13am | #12
      > I would blow-in the wall cavities with cellulose from the outsideFirst make sure there's no K&T wiring in the walls.
Balancing Density and Privacy in Los Angeles
Four 2200-sq.-ft. detached homes provide flexible open-plan housing on this Los Angeles block.
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
  • Podcast 547: Basement Insulation, Historic Preservation Resources, and Shipping Container ADUs
  • Podcast 547: Members-only Aftershow—Fine Homebuilding House memories
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
