Insulating Basement Walls
| Posted in General Discussion on June 15, 2001 09:37am
Here’s two easy ones for you guys.
1. I am finishing my entirely below grade basement. I am using 1 and 5/8″ metal studs, moisture resistant drywall. It is a dry basement, and it is heated. Should I insulate the inside of the block exterior walls? If so, would that include the wall above which starts my garage? Given all of the temperature gradients, should I put vapor barrier on the inside and outside (e.g., using polywrapped inslation)to cover air conditioning and heating issues?
One “school of thought” I’ve read about in this magazine is to just ignore all vapor barriers and insulation in this instance and let the moisture go where it needs to go, but I am confused by all the differing opinions on this issue.
2. What is the best way to seal off the top of my concrete block walls? My fundation is built (in 1978) with 12 inch open block, but the sill plate is only a 2 by 6, leaving openings through the block all the way down. Again, I have asked 5 people and been given 6 answers, all of which sound OK. I’m interested in what the best solution would be.
Thanks for your help.
Mark Righter
  1. Mark_Righter | Jun 15, 2001 09:37pm | #1
    Here's two easy ones for you guys.
    1. I am finishing my entirely below grade basement. I am using 1 and 5/8" metal studs, moisture resistant drywall. It is a dry basement, and it is heated. Should I insulate the inside of the block exterior walls? If so, would that include the wall above which starts my garage? Given all of the temperature gradients, should I put vapor barrier on the inside and outside (e.g., using polywrapped inslation)to cover air conditioning and heating issues?
    One "school of thought" I've read about in this magazine is to just ignore all vapor barriers and insulation in this instance and let the moisture go where it needs to go, but I am confused by all the differing opinions on this issue.
    2. What is the best way to seal off the top of my concrete block walls? My fundation is built (in 1978) with 12 inch open block, but the sill plate is only a 2 by 6, leaving openings through the block all the way down. Again, I have asked 5 people and been given 6 answers, all of which sound OK. I'm interested in what the best solution would be.
    Mark Righter
Double-Duty Large-Jaw Pliers
Klein's 10-in. plier wrench has a toothed V-jaw for grabbing pipe and conduit, or can be flipped around for a parallel, smooth grip.
  • Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
  • Podcast 551: Members-only Aftershow—Badly-Built Homes
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
