Insulating Basement Walls & Floor
Hops | Posted in Energy, Heating & Insulation on October 5, 2004 06:57am
I am getting ready to lay the stone on my new house and wanted some advice on insulation.  The house is in Central WI and the basement is partially exposed with stone on the upper 5 feet.  It will have hydronic heat in the basement floor.  The basement will also be finished in most of the areas that will have stone on the outside.
I have a couple of questions.
How much EPS should go under the floors?  GC says they put in 1 inch.  I am thinking a minimum of 2, but have seen 4 inches in 2 layers running perpendicular to each other.  How much is too much?  Any other advice?
Should I try and put some EPS (1/4 inch or 1/2 inch) behind the stone veneer.  The rest of the exterior walls have 2 inch EPS.  What will I gain if anything?  If I do put some insulation on, should I put the water shield under or over the EPS?
Thanks.
  1. gdavis62 | Oct 05, 2004 07:54pm | #1
    For the floor, 2" thick rigid foam, the kind with the good compressive strength, at a 4 foot width around the perimeter, is what you need.  In the center nonfoamed areas, bring your stone base up to the level of the foam top.  Then do a 6 mil poly cover, lapping all joints 6", and tape the laps.  Then mesh, tubing, and pour.
    For the walls that aren't completely covered on the outside with  2-inch foam, do the 2-inch foam on the inside face, shot and glued to the crete, then use canned foamseal to do all the cracks.
    1. gypsycatfish | Oct 11, 2004 05:40am | #2
      Bob,
      Why don't you put insulation under all of the floor/
      1. gdavis62 | Oct 11, 2004 07:32am | #3
        You don't need it beyond that four-feet outer perimeter.  It is at the perimeter where you are insulating to prevent heat loss into the substrate base and soil.  In a continuously heated structure in a cold climate, the heated space has successfully warmed the soil under the center areas of the basement.
        1. gypsycatfish | Oct 11, 2004 11:41pm | #4
          thanks Bob
          tony
Hole Saws That Are a Cut Above
The Spyder carbide-tipped hole saws cut quickly with a quick-release arbor that makes it easy to remove the core.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
