I have concrete block exterior walls which are firred out and plaster interior walls. There is no insulation in the walls. I’m in the process of drywalling over the plaster because of all the cracks. I’m looking for the best way to provide some insulation without adding too much thickness to the walls and without removing the old plaster. Thanks
-Ed
The LG Inverter Heat Pump Water Heater uses advanced inverter technology to ramp up or down in response to hot water demand, maximizing energy savings.
I have concrete block exterior walls which are firred out and plaster interior walls. There is no insulation in the walls. I'm in the process of drywalling over the plaster because of all the cracks. I'm looking for the best way to provide some insulation without adding too much thickness to the walls and without removing the old plaster. Thanks
-Ed
