In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Insulation basement along foundation wall
bkimbark1 | Posted in General Discussion on December 29, 2019 07:55pm
Hi everyone,
I just bought a house and am making some initial plans for finishing my basement and I figured a good place to start would be with adding some insulation. Along the top of the concrete foundation walls there is a gap where some plumbing pipes (which I need to secure) run parallel to the joists, and on the walls perpendicular with the joists, are pretty much empty gaps. Can/should I add insulation into these areas before finishing? What options do I have as far as insulation choices?
Also, I’ve been doing some reading about adding insulation to concrete walls. Most articles I have read have said to first check for any moisture first. The concrete walls are painted white but I’m not sure if they are a waterproofing product or not. Either way, there is not any signs of moisture, so I think I am OK to insulate. What is the best approach for insulating along my concrete wall? Foam insulation, and frame on top of the foam? Frame directly on the concrete and add insulation between studs?
I am attaching some pictures of the space. I appreciate any guidance you all can offer.
Thanks,
Brian
  1. ktkcad | Dec 30, 2019 08:24pm | #1
    There are many 'details' for these very issues at https://www.greenbuildingadvisor.com/detail-library
    Yes, Insulate the Sill Joist gaps. Remember they are 'walls' so batt insulation should be installed vertically just like stud bays. Rigid needs to have the edges spray foamed with similar closed-cell insulation as the tight-fitting boards you put in.
    "Look for moisture" that would be cracks or overspilling at window sills and sill plate. Also, if there is any 'white powdery substance' on the face of the concrete. The first two are bulk water issues, the last is vapor pushing through and bringing calcium out of the walls with it. Having painted walls, look for peeling or bubbling paint.
    Next, outside dig about 6 inches down the wall and see if they applied any asphaltic looking sealant to the outer edge and/or if there is any other kind of drainage along the face of the wall like rocks or plastic 'cardboard' that would drain down to a footing drain.
    For interior furred walls, I like the detail where an inch of XPF is pushed against the wall by the new stud wall. This means only the wall's base plate needs to be treated and sill seal would be recommended. You can creatively tie the top plate to the concrete wall's sill plate. I would suggest you use shims along the studs to force the XPF boards against the concrete wall after you straighten and plumb the new framing. If the XPF is not tight against the concrete there is room for condensation and mold. Or, use rockwool. This will dry out and you don't have to place vertical fire breaks every ten feet along the wall (pressure-treated stud/furring strip).
    And by the time you have the R15(R13) batts in the stud bays, you will be wishing you had just trenched out the exterior walls and put R10 of rigid on the outer surface.
I Wish Tools Were More Expensive
Andy Engel reflects on the price and durability of tools over the years since he entered the trades in 1979.
  • How to Frame an I-Joist Roof
  • Designer Kitchen Cabinets on a Budget
  • Podcast 459: Leaky Attic Stairs, Right-Sizing Heat Pumps, and Vapor Barriers in Dirt Crawlspaces
  • Linda Reeder: Architect, Professor, and Author
Justin Fink Deck Building Course announcement
Sign Up See all newsletters
BOOKS, DVDs, & MERCH
Shop the Store
  • 2021 Fine Homebuilding Archive
    Buy Now
    Buy Now
  • Tool Guide 2022
    Buy Now
  • Outdoor Projects
    Buy Now
  • Shop the Store
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • Issue 304 - Dec 2021/Jan 2022
    • Why You Need Blower-Door Testing
    • Passive-House Standards for Everyone
    • Window Replacement With a Side of Rot Repair
  • Issue 303 - November 2021
    • Compact Cordless Miter Saws
    • Maximize Space with Thoughtful Built-Ins
    • 10 Essentials for Quality Trim Carpentry
  • twitter
Sign Up
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
