Insulation board.
| Posted in General Discussion on January 4, 2000 11:49am
In a fairly recent issue of FH, there was an article on doing a basement floor using 2×4’s laid flat, 1 1/2″ insulation board, and 3/4 plywood subfloor. Sounds great, as I am building my own house and plan to live in the basement while I finish the rest. I can’t find any suppliers in my southern Illinois area that admits to being able to get 1 1/2″ blue board. Who makes it? Who distributes it? Thanks for any info.
Pete
  1. Guest_ | Nov 29, 1999 01:11pm | #1
    Somebody else may very well come up with a valid reason, but I cannot for the life of me find a reason that you couldn't just double the 3/4" thickness (use two 3/4" sheets instead of one 1 1/2" sheet). This would give you the 1 1/2" that you need, and the material should be readily available. I really don't know anything about basements and their moisture problems first hand. We don't have basements here. If the moisture in a basement environment would cause a problem with this solution, then I'm sure someone will speak out.
    Just a thought...
    James DuHamel
  2. Pete_Bossardet | Nov 30, 1999 10:21am | #2
    Thanks James,
    That is exactly what I am doing. It just seems that double the cutting and fitting could be avoided with the thickness that I need in the first place. Oh well, such is the life of someone trying something new.
    Pete Bossardet
  3. Guest_ | Dec 01, 1999 05:51am | #3
    pete, most of the basements we've poured since 1980 have 2" of Styro-SM, or Amoco Green board, or Foamular pink board UNDER the slab. Then you don't have to worry about the plywood and sleepers , etc,.
    I've posted the whole process here or on JLC. If you're interested I could go look for it.
    If not, that's ok, too.
  4. Pete_Bossardet | Dec 01, 1999 06:48pm | #4
    Mike, basement was poured last July, so its a little late to be putting blueboard under it at this time. I'm just insulating the shower floor in the downstairs bathroom, to do the rest of a 1600 sq ft basement seems a little too much for this area of the country. Thanks any way, you are entirely correct for anywhere North of here.
    Pete
  5. Pete_Bossardet | Jan 04, 2000 11:49pm | #5
    In a fairly recent issue of FH, there was an article on doing a basement floor using 2x4's laid flat, 1 1/2" insulation board, and 3/4 plywood subfloor. Sounds great, as I am building my own house and plan to live in the basement while I finish the rest. I can't find any suppliers in my southern Illinois area that admits to being able to get 1 1/2" blue board. Who makes it? Who distributes it? Thanks for any info.
    Pete
Tool Test: You Need a Drywall Sander
We tried out a range of rotary and random-orbit sanders to compare their dust collection, quality of finish, and user fatigue after hours of sanding.
  • The Unabashed Maximalist
  • Sharp-Blade Solution
