Insulation under Pergo flooring
bddy829 | Posted in General Discussion on August 18, 2008 04:54am
I will be installing a pergo flooring system in the next month or two. I will be installing over a cement slab. The slab is an inch lower then the existing ceramic floor that is next to it. I am wondering if I can put the half inch blue rigid foam boards on the slab then the vapor barrier and then the floor. This should then raise the floor to the desired height.
  1. Piffin | Aug 18, 2008 03:43pm | #1
    sounds good to me.
    use spray foam to glue the foam to the crete and at seams and you have the VB done.
    fengelman | Aug 18, 2008 04:13pm | #2
    I had to build up a floor almost 4 1/2 inches....I used just that, but finished with a  layer of 1/2 inch ply. but then, it was a kitchen, and the dishwasher was 1/2 on and 1/2 off this new section of floor....three years down, and no problems yet...plus that floor is much warmer than it used to be...LOL
    I wish I didn't know now, what I didn't know then
    rjw | Aug 18, 2008 04:18pm | #3
    The foam board might not be sufficient - call Pergo.
    You might consider using dri-lock (?)panels (not the paint) - they'll help protect v moisture and keep the floor surface warmer than a straight install on cement
    In Xanadu did Kubla Khan
    A stately pleasure-dome decree
    Where Alph, the sacred river, ran
    Through caverns measureless to man
    Down to a sunless sea.
    Coleridge
    Gene_Davis | Aug 18, 2008 09:25pm | #4
    rjw recommended dry-lock panels.  I think he meant dricore panels, which would be a good alternative.  They are 7/8" thick.
    Here is the link:  http://www.dricore.com/en/eIndex.aspx
    The only Pergo-like flooring I ever put down was by Wilsonart, and it went over a thin foam sheeting, which gave the floor a nice slight "cush" when walked on.  Really nice.
    With 7/8 Dricore and the foam sheet, there's yer inch!
    Follow up afterward and tell us how it went.
    "A stripe is just as real as a dadgummed flower."
    Gene Davis        1920-1985
      rjw | Aug 19, 2008 01:16am | #5
      Ah, yes, dri-core.Thx
      Coleridge
    2. bddy829 | Aug 20, 2008 12:43am | #6
      thank you everyone for your great advise. I will look into all my options and I will let you know how it goes.
Best Deck for a Steel Roof
For a metal roof, install solid decking such as OSB or plywood.
  • Use a Press Tool for Plumbing Connections
  • Remodeling Around Electrical Panels
  • Podcast 567: Soundproofing, Garage Doors, and Rotted Balconies
  • Podcast 567: Members-only Aftershow — Andrew Zoellner’s House
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
