Interior Plaster Efflorescence
| Posted in General Discussion on May 20, 2003 07:50am
I have recently purchased a 40 something year old wood framed stucco house with plaster interior walls.  One side of one wall is permanently in the shade.  Around the top of the windows on this wall the plaster is bubbling.  It doesn’t seem to be direct water infiltration, but efflorescence.  The exterior stucco and the caulk joints around the windows seem solid.  I’m guessing that when the stucco gets wet, it takes a while to dry out because the wall never sees any sun and this is causing the wood framing around the window to draw moisture inside.  I was thinking of applying a clear water sealer around the exterior of the window.  Will this work or will it cause further problems?   If it will work, what product would be most effective and how far around the window will I need to seal?  I’m used to wood siding and have little experience with stucco.
  1. Catskinner | May 21, 2003 02:11am | #1
    Juan,
    I'd be leery of sealing the stucco. Properly applied stucco should be waterproof, if it isn't, there is something wrong that no amount of sealer will ever cure.
    I'd have a competent professional in your area take a look at it. Water intrusion can be a real problem, best to fix it right away and properly.
    DRC
  2. AhneedHelp | May 21, 2003 04:17am | #2
    Do you live in an area that gets an occasional heavy snow ?
    If so, don't rule out water infiltration caused by ice dams.
  3. Piffin | May 21, 2003 04:40am | #3
    Plaster veneer on board or real plaster on lathe?
    What location?
    Insulation in wall?
    There is a possibility that this is related to condensation
Kimberley Robles, Decorative Concrete
In this interview, Kimberley talks about the importance of proper training, current concrete trends in the Bay Area, and the history of racist housing policy in San Francisco.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
