In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Is my furnance placed wrong?
cristobalceballos | Posted in Energy, Heating & Insulation on December 13, 2010 01:37am
I just bought a house in Chicago and have already been called out on something. We had an inspector come out and check our house before we bought it and it was all good. This past weekend we had people’s gas come in and check the meter. Our meter is in the house in the basement. He checked around and he saw a flaw. We have a bathroom in the basement. If you go inside the bathroom and look to your left, we have one of those folding doors. If you open it we can access the furnance to change the filter and what not. The People’s Gas company said that we need to have that door sealed off because it is a code violation. Does anyone know if this is true or is the Gas company try to screw me over?
  1. danski0224 | Dec 13, 2010 05:36pm | #1
    Doubt It
    Code violation?
    That doesn't make any sense.
    Furnace clearance to combustibles is only an inch or two on the sides. Front is usually a bit more.
    Single wall metal vent pipe combustible clearance is 6"
    If the furnace is in an enclosed room when the door is closed, I would be more concerned about the lack of combustion air.
  2. DanH | Dec 13, 2010 07:09pm | #2
    Different codes in different parts of the country.  In most areas having a sealed area for the furnace is not a requirement, but Chicago has always (since an incident with a cow a few years back) been a bit obsessive.  So this may indeed be a Chicago code thing.
  3. rdesigns | Dec 13, 2010 08:44pm | #3
    All nationally-recognized fuel gas codes (IMC, UMC, NFPA 54) prohibit furnaces from being located in bathrooms or bedrooms unless the furnace is of the sealed-combustion type, meaning the the burner is not open to the indoor atmosphere. This means that you would have a high-efficiency furnace with plastic vent and combustion air piped directly into the fire chamber of the unit.
    This code requirement is not new--it dates back at least 30 years, or more.
    Some codes allow you to get around this by installing a tight-fitting door between the furnace room and the bathroom or bedroom. The door must have an automatic closer, and have weather stripping and threshhold to make it tight, and, in addition, the furnace must have all its combustion air piped in directly from the outdoors.
    1. danski0224 | Dec 14, 2010 08:03am | #4
      Thanks for the Info
      What is the purpose of the code?
      Oxygen deprivation?
      1. DanH | Dec 14, 2010 07:12pm | #6
        I would guess a bathroom would be a hazard because any bathroom without an operable window is required to have a vent fan, even in the very old codes.  And the vent fan can create a backdraft.
        1. cussnu2 | Dec 15, 2010 12:14pm | #7
          Thats probably it....although I have had a couple of kids that fall asleep on the toilet!
  4. rdesigns | Dec 14, 2010 09:50am | #5
    Depleted oxygen and/or dangerous combustion gases that could fill a small bathroom or bedroom while the occupants are asleep--these are the reasons for the rule.
    This is a long-standing prohibition in the code, dating back to days when furnaces were not equipped with hi-temperature cutoff sensors in the flue and in the supply plenum. While the danger from appliances has been decreased by such safety controls in recent years, the danger can't be entirely eliminated. The codes do list a number of exceptions to the rule that would allow certain fuel-burning appliances in baths and bedrooms, but none of them apply in your case, except the one I mentioned about closing the furnace room off from the bath and piping all the combustion air in there directly from the outside.
  5. Tim | Dec 15, 2010 03:03pm | #8
    Maybe, but minor
    If your furnace takes combustion air for the surrounding space (ie. doesn't have two PVC pipes, either 2" of 3", connected to it) and is only open to the bathroom, then the gas company is correct.
    If the closet that holds the furnace is surrounded by a large open area, put a grill in the wall and a solid door between it and the bathroom and your are now in compliance.
    This based an odd section of the code, that dates back when sewer gases were less efectively vented and gas burning appliance had standing pilots. Created an explosive environment, potentially.
The Perfect Palette for Picking Paint Colors
For your next finishing project, look no further than the Colours of London, a curated collection of 120 colors from Mylands.
  • Cordless Drywall Cut-Out Saw
  • Podcast 461: Adding a Screened Porch, Insulating a Raised Addition, and Preventing Termites in Exterior Foam
  • Decompartmentalizing a 1940s San Francisco Home
  • Upgrade Your Window Air Conditioner
Justin Fink Deck Building Course announcement
Sign Up See all newsletters
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Tool Guide 2022
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Outdoor Projects
    Buy Now
  • Shop the Store
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • Issue 304 - Dec 2021/Jan 2022
    • Why You Need Blower-Door Testing
    • Passive-House Standards for Everyone
    • Window Replacement With a Side of Rot Repair
  • Issue 303 - November 2021
    • Compact Cordless Miter Saws
    • Maximize Space with Thoughtful Built-Ins
    • 10 Essentials for Quality Trim Carpentry
  • twitter
Sign Up
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
